It has the camera mounting spigot and rear faced off to improve access to the joystick - and air rifle/rimfire dovetail mounts.
The aluminium tube that carries the camera has 1mm of free space within it at the front end - and three grub screws to assist in centralising the OSD crosshair when zeroing to suit the buyers rifle.
Like most professional optical devices, it has user fit/replaceable batteries: It takes 2 x 18650 batteries (not supplied) which can be charged without needing to leave the rifle laying about outside it's cabinet - and can be very quickly changed in the field if you extend your hunting time beyond two hours continuous 'on' time. I get over three hours continual from recovered laptop cells because the protection circuit doesn't shut them off early.
A 'Y' lead can be connected to the monitor cable to run a DVR or additional screen on an extension cable.
I can supply it customised with a choice of lenses:
The very best performing F1:1.4 75mm Cosmicar C mount TV lens at £400
Or with a choice of 50mm lenses:
M42 SLR with adaptor - or F1:1.4 Cosmicar C mount TV lens at £350.
I am currently out of plain top scope mounts and may replace the weaver top mounts if replacements arrive before this is packed up and sold.
This video was recorded with the exact same spec camera and 75mm Cosmicar lens:
