Gen 1 NVD for Astronomy
SJLPHI
Post by SJLPHI » 06 Aug 2022, 10:13
Hello, I've used Gen 2+ and 3+ extensively back in the army but I've been medically discharged a long time ago and recently just bought a Yukon Spartan 1x Gen 1 NV monicular to watch the stars.
Do you guys know where to best look for adapter to link this up with my MEADE ETX 70?
Re: Gen 1 NVD for Astronomy
Post by sunndog » 06 Aug 2022, 10:21
Think you might have to use something universal...can you show us the eyepiece of the telescope and its dimensions
The yukon dsa (dayscope adaptor) might work if you can find one
Thermal hunting forum
SJLPHI
Post by SJLPHI » 06 Aug 2022, 10:45
https://www.google.com/search?q=meade+e ... l1KVB9kwvM
this is what they look like, 20mm I believe for lens holders.
Post by sunndog » 06 Aug 2022, 11:28
I'm assuming the spartan has at least on 1/4" thread underneath it?
Have a measure and a look at the yukon, cobra, and pulsar DSA's
SJLPHI
Post by SJLPHI » 06 Aug 2022, 15:40
No threads on the Yukon, it's all packaged with focus dials on the front and back lenses both rubberized.
Post by sunndog » 07 Aug 2022, 06:17
Not on the lenses. On the underside there should be one or two threaded holes
I had the previous model to the spartan years ago, same thing just a different name.
They do helmet mounts and stuff for it and I'm guessing they still do?
If not then there isn't an off the shelf option and you're gonna have to get creative
SJLPHI
Post by SJLPHI » 07 Aug 2022, 14:05
Yes, there are two 1/4" threads under the device, which I do use with a head mount.
Post by sunndog » 07 Aug 2022, 15:22
I've never actually seen a head mount for it in person but the dayscope adaptors used both 1/4" holes iirc. In your case you could use either one as an adjustment
Lambda
Post by Lambda » 10 Aug 2022, 11:27
Hi Sulphi.
Beside the question of mechanical adaptation, just to mention that the ETX 7'0 has a F/D around 5 if i do not mistake myself (i own one exemplar).
(I) Without the genuine lens from the NVD: prime focus configuration.
For a gen 1 (one stage) NVD, this optics is quite slow and would not "feed" a lot the photocathode of our NVD.
It would be, IMHO, perhaps a better option to use the fastest lens as possible (1.4 or faster, for instance) and to do wide field sky observation.
Nevertheless, if you want to use your ETX70 as it is, with your gen 1 NVD, with a good dark sky, it can be interesting to aim star clusters, bright galxies (M31, M81,...) and especially some globular clusters like M13 or M92 which are in general nice near infrared emitters.
Other option you could consider would be to add a focal reducer to your ETX 70.... Something like a x0.5 reducer.... It would bring your scope to a resultant F/D=2.5: more friendly with your NVD (brighter images).
(II) with the genuine lens from the NVD: afocal configuration, with using a proper exepiece.
with an eyepiece having a longueur focal length than the genuine lens from your NVD, It would allow you to "accelerate" (faster resulting F/D aperture) your whole optical system, at the cost of the field of view, it is true....
Anyway, good luck with your project and enjoy the result !
Regards.
Lambda
