Advice needed pls lads
Bedsy40
Post by Bedsy40 » 28 Aug 2019, 12:27
Hi lads I am after a bit of advice, I'm new to nightvision game, still using a lamp at the mo, the dilemma I have is that I have 3 rifles, a. 223,. 17hmr and a. 22, I would like to have night vision for all 3, I was looking at getting a pard 007 add on but the only rifle with a scope with parallax adj is the. 17 hmr, currently using hawke airmax30 ir, so do I change the other scopes to one's with pa (can you give us any recommendations, I'm on a budget) or go the front mounted route which is more expensive and I'm not sure about it {opinions welcome) any advice welcome, thanks guys
flash69
Re: Advice needed pls lads
Post by flash69 » 21 Sep 2019, 10:45
hello, no replies ? did you get a night vision set up, the way i see it you need an add on that will go on your 3 rifle scopes only one having a parallax adjustment, look on the Digital Night Stalker web site, Damien make some good gear, these should go on any day scope, take a look at his add on, i had one made with the screen on front of battery box and not on a scope mount, i got a home charger and car charger 12 volt, around £160 but your need a I/R torch and an extra stock pad, ebay 291932941445. cheers
