Wanted IR illuminator
Hi all
Looking for an IR to be mounted underneath a Yukon spotter ( cannot be too big) to give me more range , looking to spend around £50 what have you got?
- some bloke
- NON EMMET
Re: Wanted IR illuminator
Maybe its my dyslexia but the 'cannot be too big' reads to me as the bigger the better - or not to be big... just trying to help mind.
Nope I mean it can't be too big as it wouldn't fit under the spotter
- some bloke
- NON EMMET
This is one of the better bang for buck fairly compact ones near your budget.
http://www.nightvisionstore.co.uk/black ... 2x17313901
These cost slightly less but in my experience that type of torch has floppier heads:
http://www.nightvisionstore.co.uk/black ... 2x23877906
If you use a bike handle bar camera mount you can screw the threaded portion into the spotter.and the clamp section will hold any size ir torch.
Mount is about £3 off fleabay
- some bloke
- NON EMMET
I have bresser spotter that I got cheap picattiny
rail screwed to underside then adjustable torch mount with old t20 torch with AS pill ,as some bloke said use torch to hold , I have t66 surplus to requirements (probably to big for you)and t2o black sun ii pill (only)
Regards lee
Using srx now
Regards lee
Using srx now
hi mate i got some IR's here if your still after one ?
T50 IR + Dual Mode Remote Tailcap Switch £27 posted
Ward b672 Fitted With Black Sun 2 IR £47 posted
Black Sunnranger Ruby IR £70 posted
As New Ludicroslumens Sunranger IR £65 posted
Older N1000 IR laser None multipower setting just on/off £50 posted
CZ 17 HMR / Tasco 3-9x50 AG
Cheers Anthony pm'd
Problem with the yukons and Bressers is the viewing screen/eyepiece , if you use a 3.5 or 5 " screen really transforms there use combined with a 50mm lens i.r easily spot 300yds plus...
