As above. Older model, uses 2 batteries. One tiny dust spec otherwise clear, comes with J arm, headset, pelican case and soft bag, and belt pouch in camo. I've had this sitting a couple of years, not used one set of lithium batteries through it, so little used, previous owner said he'd had 2 hours through it. If I totted up the odd times I've played with it, I'd have done about the same. A spare pair of unused lithium batteries are available if you're collecting, cannot post.
Great bit of kit for sure, I just don't use it. Going more towards buying a thermal camera, so offering this one at £1800 plus any delivery costs. Pm me with email addy for any pics. Don't ask me what the number of the module is, I'm not a technician, and I wouldn't know how to open it up, much less be inclined or brace enough to do so, I just know you you can see very clearly everything in the dark with it!
Advertising this elsewhere too, thanks.
PVS 14 for sale
spiralviral
Re: PVS 14 for sale
As above. Older model, uses 2 batteries. One tiny dust spec otherwise clear, comes with J arm, headset, pelican case and soft bag, and belt pouch in camo. I've had this sitting a couple of years, not used one set of lithium batteries through it, so little used, previous owner said he'd had 2 hours through it. If I totted up the odd times I've played with it, I'd have done about the same. A spare pair of unused lithium batteries are available if you're collecting, cannot post the batteries.
Great bit of kit for sure, very clear in the dark, but I just don't use it. Going more towards buying a thermal spotter camera, so offering this one at £1800 plus any delivery costs. I can send pics via email via pm, apparently the files are too large.
Advertised elsewhwere also, thanks.
spiralviral
Re: PVS 14 for sale
Er, not yet 23.56 in Grampian, sorry haven't as yet received it this end - paraffin driven iPad linked to clockwork dial-up bb here, I hear other places are going for either 4or 5g, it'll be great when the Nippy Soorploom gives us an actual mobile signal!
spiralviral
Re: PVS 14 for sale
Spec of tube:
100184748
06/35
Oct 09
btw, still working as well as before, after reattaching of eyepiece, the tiny dust speck must have been on the eyepiece and not the actual tube, because it is now gone, and the view through the unit has no spots at all - result!
100184748
06/35
Oct 09
