.204 Ruger Semi Custom Foxing Rifle
blindasabat
Post by blindasabat » 07 Nov 2016, 16:35
Remington 700 Stainless with 24" Barrel, 1x12 twist, screw cut 1/2 x 20 UNF
GRS Adjustable Hunting Stock in Brown, right handed
Devcon and Pillar Bedded
Timney 1.5lbs - 4lbs Trigger
Custom 416 Stainless Picatinny Rail for night sight such as Drone Pro, Pulsar etc made by Dave @ Valkyrie Rifles
Tactical Bolt Handle, also fitted by Valkyrie Rifles
Jet Z CQB Sound Moderator
Redding Type S FL Match Die Set
60 new unprimed Hornady cases
1lb tub of Hodgdon 4895 with 38 rounds loaded from it
30 Hand Loaded 39gr BlitzKing rounds
160 x 39gr Sierra BlitzKing bullet heads
various factory loaded rounds
Bore Guide
Sling
This is a great foxing rifle with fantastic and consistent accuracy with virtually no recoil.
This allows you to see through your scope when shooting. If you are into Ballistics, the .204 is very comparable with the 22/250, some say better??
This rifle is virtually new and has only fired 69 rounds up to now, round count may increase slightly as I will still use.
Can supply with unused ordinary Picatinny Rail if Custom Mount is not required
Set up cost over £2,500
Big Saving, offered for sale at £1,400 with all the bullets, powder, Dies etc but would need to be face to face transaction.
Or, £1,200 for Rifle, Mount & Moderator to be sent RFD-RFD
Any inspection welcome or any questions please get in touch
.204 Ruger
204 Ruger Remington 700 003.jpg (71.02 KiB) Viewed 5205 times
.204 Ruger 2
204 Ruger Remington 700 004.jpg (84.75 KiB) Viewed 5205 times
poppy mae
Re: .204 Ruger Semi Custom Foxing Rifle
Post by poppy mae » 07 Nov 2016, 19:10
That is sexy.................
blindasabat
Post by blindasabat » 27 Nov 2016, 20:09
Nobody needing a .204 ??
Price dropped to £1000 for everything in photos
Rifle, Moderator, Dies Bullets etc
This rifle shoots fantastic groupings with very little recoil or noise.
When using Night Vision you see what you have shot through the scope!
poppy mae
Post by poppy mae » 27 Nov 2016, 20:32
Yep!..... but timings all wrong
blindasabat
Post by blindasabat » 28 Nov 2016, 12:18
Yep....sounds just like my luck poppy mae :roll:
stacka
Post by stacka » 29 Nov 2016, 00:31
How much without the stock
blindasabat
Post by blindasabat » 29 Nov 2016, 18:11
Hi Stacka, not sure, I hadn't really thought of it but make me an offer if you are interested,
do you want custom Picatinny rail or standard one?
blindasabat
Post by blindasabat » 04 Dec 2016, 18:42
Final price drop if anybody is interested
£900
