Mk1 Photon Doubler Help!
Rasor
Post by Rasor » 16 Aug 2016, 08:16
Hi all,
This is my first post so please be gentle :lol:
I have an original Photon scope and have acquired a doubler and adaptor to fit onto the objective lens. Have found a ring screwed into the inside of the objective lens which I cannot move! Is this possible to remove? Or do I need a different adaptor?
blueeyes
Re: Mk1 Photon Doubler Help!
Post by blueeyes » 16 Aug 2016, 11:28
This might help if its not the Marky type
https://www.youtube.com/watch?v=DD2juJhiiAE
Rasor
Post by Rasor » 16 Aug 2016, 12:32
Hi blueyes,
Thank you for your reply.
Have watched the vid and the scope in it is the new version of the one I have. I have one of the originals I bought when they first came out. I did see the metal tool he used to remove the ring from the objective lens which looked homemade so I will try and replicate it!
Unless anyone has one I could borrow?
Rasor
rodp
Post by rodp » 16 Aug 2016, 18:49
Mine just had an adaptor on the doubler (a piece of plastic tube) that pushed over the photon. You secure them with silicon sealer.
Nipper64
Post by Nipper64 » 16 Aug 2016, 19:34
Hi mate,
Can you put some pics up of your doubler and adapter ? And the screw your on about. Cheers Gary.
Rasor
Post by Rasor » 17 Aug 2016, 06:11
Hi Gary,
Will do later today!
Was out chasing Charley around till late last night with a full moon and no cloud!! :cry:
Rasor
Nipper64
Post by Nipper64 » 17 Aug 2016, 18:17
Had a look at my mk1 and it's the same as my xt, so all you need is a square of metal. Or a thin long nosed pliers will do it. Atb Gary.
Rasor
Post by Rasor » 18 Aug 2016, 09:13
Hi Gary,
Thanks for the info, was it difficult to release? I am presuming that Yukon may have cemented the ring in place?
Rasor
Nipper64
Post by Nipper64 » 18 Aug 2016, 12:51
Hi mate ,
They are quite easy to get undone just a bit of loctite on them. Atb Gary.
Rasor
Post by Rasor » 18 Aug 2016, 13:25
Cheers Gary,
Got a piece of metal plate and gonna sort it this evening hopefully before I go out.
Thanks again for your help!
