New to night vision
Hunter247
Re: New to night vision
Post by Hunter247 » 17 Aug 2021, 09:22
jeffo wrote:
16 Aug 2021, 23:27
I can get all night out of 1 battery but always carry a spare, as I spot with a thermal, and it's only put on to take a shot, hope this helps
Thanks for that. I have plenty of those batteries here and a couple of chargers so should be ok. Could I ask you if you have mastered the range finder on the wraith. I have it set to the coyote setting and I haven’t a clue how to use it. It would be useful as I struggle with range estimation while looking through the wraith at night.
John
jeffo
Post by jeffo » 17 Aug 2021, 15:10
No I don't use it as I got a range finder mounted on the rifle
Think you can put the range finder on custom
Post by phoenix » 17 Aug 2021, 16:31
The rangefinder on the Wraith (and a lot of NV scopes) is known as a stadiametric rangefinder.
The idea is that you select an animal from the menu that's about the same size as the animals you want to shoot
The range finder will have 2 horizontal lines, one of which you can adjust
You place the fixed line along the back of the target animal and then move the adjustable line until it's along the belly of the animal.
At that point the range to the target should be displayed.
How accurate the range displayed depends on the actual size of the animal and how it's oriented to you.
The animal also needs to be stationary while you make the required adjustments to the scope
That was a long winded explanation.
Trying to get it to work in the real world is even more long winded!!
I honestly don't know anyone who uses these built in "rangefinders"
Post by sunndog » 17 Aug 2021, 16:40
Stadiametric range finders dont exist as a thing in the real world and I wont hear anybody say otherwise :lol:
Thermal hunting forum
Hunter247
Post by Hunter247 » 17 Aug 2021, 20:17
Ok, I have a Sirius xtl on it's way. Just bought the lazer as I have good quality batteries here. Stadiametric, now theirs a big word, but I get the drift now. Its probably better for a static target and less useful for a target that on the move and a quick shot is needed on . That's if I am reading between the lines propper of course. The independent laser. How does that work, can it be connected to the wraith so that a range number is visible on screen or is it totally independent altogether. I warned you I know nothing about night vision so I appoligse for all the basic questions lads, but it's great to get answers and a bit of guidance.
Post by sunndog » 17 Aug 2021, 20:51
The addon lrf's are a totally separate unit you bolt onto the side of your scope and then basically zero to your reticle, you can see the splash through the scope.
It then displays the range on the back of the lrf unit
It is possible to make a stadiametric rangefinder work so companies list it as a "feature". Very few people use them
Rangefinding with n.v takes some practice and knowing more landmarks around your shoot helps a lot. Static shooting is a good place to start
Pick a place to wait out and pace out some fence posts or whatever in daylight. Even sticking a marker of some sort out in the field wouldn't be the worst idea
jeffo
Post by jeffo » 17 Aug 2021, 21:18
If you have a range finder that will work in the day check out various distances, and get to know the ground you are shooting also take note of back stops, as things looks totally different in the night, looking through NV, like mentioned above
Hunter247
Post by Hunter247 » 18 Aug 2021, 17:07
sunndog wrote:
17 Aug 2021, 20:51
Good ideas their, thank you. What in your opinion would be a good choice lrs for mounting with the wraith.
Hunter247
Post by Hunter247 » 18 Aug 2021, 17:17
jeffo wrote:
17 Aug 2021, 21:18
Believe it or believe it not the ground I shoot I have shot over for 30 years but when I look through NV as you say everything looks different and I get a bit lost range wise. But I will do some rangfinding during the daylight hours.
Post by sunndog » 18 Aug 2021, 17:51
LE-032 is the most popular lrf unit sold by everyone these days.
There is some faff involved mind. Try the search function on here
