501b IR for the Photon, scopeless, N550 etc + gen2/gen3
Post by some bloke » 02 Jan 2014, 01:36
I have revised the LED used in my Photon/N550~N750, scopeless/gen 2/gen3 IR:
They are brighter and have a tighter beam due to their smaller point source behind an aspheric lens. As the elements of the LED are much finer than the thick Oslon Black 'bar' these can be focused very tight with only minimal shadows. They are slightly less powerful than the Oslon Black SFH 4725S, and are now suited to all rimfire ranges. They still only draw 700ma - so have better run times that the Oslon too.
:thumbup:
The standard reflector has lathe modifications prior to removing the reflective surface and spraying them black. These have a budget aspheric lens that I sometimes have to slightly grind the edges of to fit into the head - so they may have small chips around the fitting lip that do not affect the light collimating effect, and are not seen when the torch is assembled.
As you can see it sits very nicely onto the Photon accessory rail mount with a 25mm low weaver scope mount. To be used only with an 18650 battery.
And you can now expect it to perform better than this: The first rabbit is about 60 yards away, note you can see much further beyond it - and also note the pellet and brain matter exit as the strike is completed. I don't say that to be gory in any way, I'm pointing out the clarity that the IR can reveal even when the Photon was not as well focused as well as we now know it could have been.
http://www.youtube.com/watch?v=e5yxfAwwzVM
Price is £28, or £36 with a dual mode remote tail switch: Add £6 RMSD to any package size or weight to the UK.
I also supply a more powerful one with better lens and focal spacer with an Oslon Black IR LED inside for rear add-on rigs at rimfire ranges for £45 (as shown across the top of my signature picture.
My paypal addy is: davidgeorge69@btinternet.com
Please leave a message in the paypal notes box indicating your forum name, real name and addy, and what the payment is for.
gupster
Re: 501b IR for the standard Photon at subsonic ranges.
Post by gupster » 29 Jan 2014, 19:24
Just ordered one through PayPal any problems drop me a pm.
bikerdood
Post by bikerdood » 12 Feb 2014, 20:50
Order placed and paid through Paypal Dave.
Many thanks, Craig. :thumbup:
Post by some bloke » 13 Feb 2014, 01:59
Posting it this morning Craig thanks.
Expect to sign for it before 1pm tomorrow. :thumbup:
bikerdood
Post by bikerdood » 14 Feb 2014, 14:57
Received it today Dave, everything looks great, I just need to pray for a break in the weather now to get out and test it. Lol.
Thank you for your amazingly prompt service.
Cheers, Craig. :thumbup:
Post by some bloke » 17 Feb 2014, 23:08
Out of stock for now - the more expensive ones with costlier components in are still available
Post by some bloke » 25 Feb 2014, 00:36
Back in stock with a revised slightly brighter and tighter beam.
darran77
Re: 501b IR for the Photon, scopeless, N550 etc + gen2/gen3
Post by darran77 » 07 Mar 2014, 19:03
Hi Dave as requested ,for my photon
'one of these and a tail switch please - £42 sent to your paypal'
cheers
Daz
darran77
Post by darran77 » 11 Mar 2014, 17:12
Recieved it today , thank you . Now fitted with a fresh battery and ready for dark.
daz
