Project kit includes
1x dismantled but fully working xgen digital monocular. The objective had been changed for a board cam and there are two lenses for it. If you couple it with the included scope you can see scope image through the monocular viewfinder. At night you will need plenty of ir illumination.
Scope is a 4-16x56 ags but with a loupe instead of the original ocular... Don't ask! And I don't have the original ocular. The scope is a beat up and the mag ring can be stiff but it held a zero last time I tried it. It's had a bit ofa tough life as a project mule.
Also included are two red dot type sights, no idea what make. The round style one has a battery and works and the other worked before being popped in the box.
If I find anything else kicking about I will chuck it in.
£90 for the lot delivered to your door. Ppal is fine, no extra fees
