cav123
Post
by cav123 » 12 Nov 2013, 17:54
Hi chaps got this form an old cannon camcorder and was going to try and fit it to a scope but not going to now so if anyone wants it for swaps anything lying around lights cams etc thanks cav
Some say I was born to kill so kill is what I shall do!
sedstar
Post
by sedstar » 15 Nov 2013, 08:28
i had a "go" with one of those, and got mine working.
i dont know about YOUR unit and how YOURS worked? But, i dont see the "loupe" and mirror in your pictures?
most of them used the loupe/mirror casing unit... because the deflection wiring is reversed on most (all?) of those camcorder CRT units...
(they are made to look at the picture reflected off the mirror, withou the mirror, the picture is "backwards" left to right.
you CAN "swap" the deflection wiring around from side to side... or, just use the mirror/loupe assembly that came with it (assuming it had one)
you probably already know all this, as you salavaged one, just in case and all is the only reason i mention it...
Hilbily
Post
by Hilbily » 15 Nov 2013, 15:57
Many don't use a mirror, depends how the viewfinder is made. 4 out of 5 so far for me had no mirror.
I don't know what kind of number it actually is, but the resolution of these CRT screens is great, well worth using them in my opinion.
One persons junk can well be another's treasure.
cav123
Post
by cav123 » 15 Nov 2013, 17:21
Yeah there was no mirror in this one that's how it came out of the camcorder
Sent from my Nexus 4 using Tapatalk
