irlightbuilds T20ir £45
SikaStag
Post by SikaStag » 30 Oct 2013, 16:25
Back in business.
After what seemed like an eternity waiting for things to be delivered. Finally got them.
T20ir. 3 mode driver fitted. 100% 50% and 5%. £45 inc postage.
I only send signed for insured, hence the rise in price to £45.
Rat tail clicky switches specifically for the T20. £6.50 + p&p, If sent with a T20. No extra postage charge. These are electrical switches not air pressure. Two buttons on the end. These have there own replacement Tailcap, all one unit.
80 in stock.
Green and Red led T20's are £41 postage included.
I have not had time to test the Green Leds. Too busy making and packaging illuminators to be sent out. I have a few customers that will test them out and give a review.
Ian
stubbs4612
Re: irlightbuilds T20ir £45
Post by stubbs4612 » 31 Oct 2013, 23:30
SikaStag wrote:Back in business.
80 in stock.
Ian
Hi,The rat tail clicky switch for the t20 you mention above are these remote switchers ifso how long is the wire and is there a button on there that turns it on/off ie:-press for on then press again for off if this is the case i would buy 2 from you please.
rgds stubbs4612
SikaStag
Post by SikaStag » 01 Nov 2013, 00:28
I have never used one of these before. I have not even tested them. The wire is coiled then goes straight to the pressure switch. There is two switches. The first switch nearest the T20 gives a click like the T20 tailcap does. I am guessing that is your on/off button and the second button is noiseless. I am guessing that s for the modes. I will check one out tomorrow on a T20.
Ian
stubbs4612
Post by stubbs4612 » 01 Nov 2013, 09:47
SikaStag wrote:I have never used one of these before. I have not even tested them. The wire is coiled then goes straight to the pressure switch. There is two switches. The first switch nearest the T20 gives a click like the T20 tailcap does. I am guessing that is your on/off button and the second button is noiseless. I am guessing that s for the modes. I will check one out tomorrow on a T20.
Ian
Hi Ian,I think you must have misunderstood me,I dont have one (wish i did) i just thought the one,s you have had the feature,s i was after,I have 2 t20 and would love have remote switcher,s for them with the on/off button instead of keeping you thumb on it
rgds stubbs4612
SikaStag
Post by SikaStag » 01 Nov 2013, 09:56
I just checked the tail switch. You click it on then by the slightest pressure applied it goes through the modes using the same switch. The second switch is the one that you mention. you have to keep your finger on it. For like SOS type flashing, quick.
I am impressed.
Ian
stubbs4612
Post by stubbs4612 » 01 Nov 2013, 10:32
SikaStag wrote:I just checked the tail switch. You click it on then by the slightest pressure applied it goes through the modes using the same switch. The second switch is the one that you mention. you have to keep your finger on it. For like SOS type flashing, quick.
I am impressed.
Ian
so ian what you are saying the switch you have you have to keep your finger/thumb on for the light to stay on??just like any other remote switch,i was hopeing for one that you could click on then click off when you,ve taken your shot instead keeping your finger/thumb on the pressure switch,you see i have arthritis in my hand,s thats why i dont like to keep the switch pressed in with my finger/thumb all the time i need it on,I hope this make,s sense.
rgds stubbs4612
SikaStag
Post by SikaStag » 01 Nov 2013, 10:52
Mate did you read the above post. Read it again
It has TWO switches. One is OFF/ON then touch to go through the modes. That means you click it the torch stays ON, you click again it goes off. or hjust touching it and not fully clicking it allows you to go through the modes whilst the torch is still switched ON.
Or. The second button is the one you mention, Hold it down for the torch to come on. It has both the functions in one switch. I hope this has made it clearer for you.
It is what you are looking for. Just do not used the second switch.
Ian
stubbs4612
Post by stubbs4612 » 01 Nov 2013, 12:07
SikaStag wrote:Mate did you read the above post. Read it again
Ian
Great Ian now i understand i must be having a senior moment,it seems they are just the remotes i need,can order 2 from you please and let know how to pay (sorry i do not have paypal) but cheque/bank transfer or cash will be fine,let me know cheers.
rgds stubbs4612
SikaStag
Post by SikaStag » 01 Nov 2013, 12:09
Send an order to the email in my signature writen in Red. I will then send you my Bank details.
Ian
stubbs4612
Post by stubbs4612 » 01 Nov 2013, 12:20
SikaStag wrote:Send an order to the email in my signature writen in Red. I will then send you my Bank details.
Ian
DONE.
rgds stubbs4612
