For sale tuxing PCP compressor
vincy
Post by vincy » 25 Jul 2023, 18:36
Selling my TUXING Pcp Air Compressor 4500 PSI Portable PCP Compressor, bought new but never used £150 Cwmbran gwent
• 【Portable design and light weight 】 makes it easy to transport to the range or field; Features a sturdy carry handle and rubber feet;
• 【Built-in drain system】Inlet drain valve system,remove deposit with drain valve screw to avoid and reduce maintenance;
• 【Fast charging speed】The maximum pressure of this product is 4500PSI, which makes it only takes 15min for the pressure of a 0.5L diving bottle to rise from 0MPa to 30MPa;
• 【Over-temperature protection】Smart overheat auto-shut off prevention technology prevents permanent damge;
• 【Power Adapter】Can be operated using an electrical outlet or vehicle battery with flexible AC/DC (123V/12V) operation.
vincy
Re: For sale tuxing PCP compressor
Post by vincy » 26 Jul 2023, 19:39
NOW SOLD
