This USED truck spotter has a very powerful magnet that will plonk and stay on a steel roof or rail at 30MPH - probably much faster but I don’t want to trial if or when it lets go. It features an expensive high quality KPC camera with an expensive 50mm Cosmicar TV lens for better than average imaging.
The camera/sender unit has a rechargeable battery that will provide about 5 hours constant use. A Uk plug mains charger is supplied. A mini weaver rail is securely fixed to attach an IR illuminator torch which is easily reached out the drivers window to double up as a handle to pan and tilt. The video image is transmitted via radio signal to a 7" monitor in the truck to avoid any cables trailing through a window or sunroof that can impede steering or maneuvering a rifle. The FPV radio signal does not suffer the usual lag that spoils wifi signals.
The battery in the 7" high definition FPV receiver monitor doesn't last very long - so it is supplied with a 12 volt cigar lighter power source. An IR illuminator torch with an upgrade IR LED pill is included - requires one 18650 battery - not supplied. A no obligation demonstration is offered at East Leicester any evening well after dark.
A brief field test video will follow when weather permits - but as the monitor doesn't have a record function I'll have to use an alternative viewing device that records.
Price is £300 collected (preferred with demo) or add £15 for RMSD delivery to UK postcodes.
A short video instead of photos: https://youtu.be/sLR5V05SbJI
