Odepro KL52 Plus zoomable SALE
Greylag80
Post by Greylag80 » 09 Nov 2020, 13:22
Great condition (hardly used as now have Pard008LRF)
x4 Bulbs (IR, White, Red, Green)
Fully zoomable
x2 18650 batteries and charger
Hard case
Rats-tail unused
£45.00
Adjustable Focus:
Zooming out the hunting flashlight to be used as a spot light can reach out as far as 1350ft in high mode. Zooming in as a flood light provides a wide view when you are searching targets.
Interchange 4-colour LED Modules:
4 different colour lights are included in the hunting set--red light, white light, green light and IR850nm light, can meet all need when you are searching for different targets in various hunting situations.Modules are easy to load and unload.
Smart Remote Switch:
Intelligent pressure switch can free your hands when you are holding your shotgun. Press and hold the button to turn the light on and release to turn it off. The button makes no noise at all.
2-type flashlight mount:
The K185 aluminium mount can be installed in shotguns with Picatinny rail freely; the POM high strength quick-release mount can fit multiple scope sizes, no worry about different gun size.
Weather, water and shock resistant:
Enhanced aircraft aluminium body designed for rough outdoor use, that is perfect for using in the rain, wild forest, which can be soaked in the water for a short time.
Slight scratch (<2mm) on metal - does not affect performance at all.
bobbydazzler
Re: Odepro KL52 Plus zoomable SALE
Post by bobbydazzler » 09 Nov 2020, 15:37
I will not be buying it as per pm thanks
