For Sale SunRanger IR SOLD
Post by Ttocs » 28 Jun 2020, 23:13
I was going to hang on to this but I seem to be accumulating torches.
For sale my Sun Ranger IR torch.
It’s based on a 3 power level AS 850nm IR mk2 torch from Ludicrous Lumens.
It’s got the Yukon 50mm 1.2 lens fitted
Currently running a Torch Factory ‘turbo’ output 850nm IR LED (must only be run on 1 18650 battery)
Also comes with LL AS 850nm and 940nm pills and LL 2 battery extension tube
Great torch with zero head wobble. With the 3x lens and the ‘turbo’ pill It’s really powerful when zoomed in on full power. However, the lens produces a good soft beam on flood so the torch, with its 3 output levels and wide focal range, is very flexible too. Perfect torch for sensitive NV like the Pulsar without loosing the ability to view at extended range.
£75 posted mainland uk
