I have a Pard NV008 here ... it is the non laser rangefinder model ( LRF)
But I have attached to the side of it a
Custom riflescopes ( CRS) LRF on the side .. operated with touch of a button Velcro on stock ... you can see the LRF flash in sight picture and adjust the mount so that it’s hitting your chosen zero .... then easily ping your target and know exactly how far ... display is show. At rear of the LRF
The Pard NV008 is currently set up with the latest firmware for pards LRF model so you have the increased power to onboard vcsel IR & you have the PIP box option etc
Also the mount has been been drilled and tapped with m4 grub screw by Phoenix of the NV forum to allow for easier centering of the crosshair on screen for zero
Included is padded case , USB cable , instruction booklet
The unit & the LRF and adjustable mount .
What’s wrong with unit
Two things ....
1. Missing rubber eye cup which doesn’t effect the use at all
2. Slight wear on the rubber buttons colour ... resulting in white edge to forward most button
That’s it
£500 incl Postage
Brilliant unit only selling due to upgrading
Paul
