17mm driver
17mm driver
Wanted 1 amp 17mm 3 mode driver/circuit board , only need one , possibly 2 , anybody got any knocking around ? got single mode ones , at a pinch could do 700ma 3 mode.......ta
- some bloke
- NON EMMET
Re: 17mm driver
I have a good few 17mm drivers laying about redundant.
I can pop some 700ma in the post for you - think they might be 3 mode but memory fade...
Also have plenty 1050ma one's but can't recall which are single mode and which are 3 mode.
PM me your addy pops.
Re: 17mm driver
Cheers Dave , ideally need a 3mode , got single mode ones , will pm you Dave....
- some bloke
- NON EMMET
Re: 17mm driver
Some of them are 1050mah AK47a's which you can solder across points to make the relevant modes you want, and remove one of the chips to make them 700mah. Read about sorting the modes here:
http://budgetlightforum.com/node/310
Others are 700mah but ISTR might be single mode.
Packed ready to post on Monday.
