T50 torch shrouds
T50 torch shrouds
Post by some bloke » 13 Jul 2016, 14:12
I have a small batch of T50 torch shrouds that are a direct swap for the standard bezel. Simply unscrew the bezel and screw in the shroud: They add about 80mm to the front of the torch.
They are designed to block or reduce the torch light from reflecting from the sound moderator into the riflescope - sometimes seen as a sort of light haze spoiling the image the user sees on his viewer. (Depending on barrel length and position of components)
They also narrow the viewing angle that lampshy quarry can see the glowing aspheric torch lens from.
Price is £13 + £7 RMSD.
Re: T50 torch shrouds
Post by blueroll » 14 Jul 2016, 08:12
do you have any for NM800 or XSearcher ?
Post by some bloke » 14 Jul 2016, 12:12
blueroll wrote:do you have any for NM800 or XSearcher ?
Sorry, I only got them made for my Kwik fit add On rigs which have integrated T50 illuminators - which means they will eventually get used if they don't sell.
I kinda anticipated there would be enquiries for other torches but I can't justify tying up funds in batches of so many different varieties made up - particularly when some smart ass will likely complain about £20 for a piece of plastic delivered to them. lol.
Maybe someone will 3D print some friction fit push on/in one's that can be made as needed.
Post by blueroll » 14 Jul 2016, 16:13
Okay. Thanks for the reply.
