Photon xt 6.5x50s + pulsar doubler
hairlesshunter
Photon st 6.5x50s plus pulsar doubler plus 30mm mounts for sale all come with boxes and are in very good condition I bought it in September so 10 months old I can include receipt the doubler can be removed without knowing it was ever on just in case it should ever need to go back under warranty as some of the photons with no plastic spacer but now have it in so a doubled couldn't be used with out a connector £360 posted
Re: Photon xt 6.5x50s + pulsar doubler
Re doubler....is yours the Yukon 1.7x lens? And is the anti doubler fit extra ring removable..... Just for clarity...thanks
And, will you sell the doubler lens separate?
hairlesshunter
Hi philong it's the Yukon 1.7x Lens Converter 2.5x50 Doubler and not sure about the anti doubler fit extra ring removable there's no extra ring or connector the doubler just fits straight on to the photon night vision and you can remove and you wouldn't even know there had been one on hope this helps
Thanks..is doubler available as is?....,I only asked the other question as photons sold today have another ring glued in front lens filling the exposed thread that a doubler would fit onto...some owners have carefully removed the blocker ring.
hairlesshunter
Hi Phil sorry no trying to sell as a job lot . This one I have as had nothing removed to fit the doubler as I say I most have got one of the last ones without the retaining ring cheers Craig
OK thanks....
hairlesshunter
Now sold cheers all
