The new Range finder that can be used at night.
CustomRifleScopesUK
This is the new type weapon mountable range finder that can work with your NV scope as its laser ping can be seen.
In the picture you can see its half the size of the old type
in this photo you can see how much smaller it looks on your scope
this photo you can see it has fog mode and inclineometer.....also does speed gun
so it can fit to your NV build.
They are available here
http://www.customriflescopes.com/shop.h ... y=13698432
Use this code to get money off, this code is exclusive to night vision forum guys only !!! MOXQ3YCWXRXA
Splatty
Splatty
Re: The new Range finder that can be used at night.
£2 off off or have I got it wrong?
G
G
I presume to use this you need to have the ILluminator switched off otherwise you will not see the laser itself pinging on the quarry?
I might be wrong, but I think you leave the illuminator on.
Assuming you're using the range finder with an NV spotter, then with the illuminator switched on you can see the target you want to range.
Switch on the laser and the laser "spot" should be visible in the spotters field of view.
"Paint" the target with the laser spot and read off the range on the digital display at the back of the rangefinder.
I just zeroed the laser to the same POI as the scope, no need to see the laser once you have done this.
Anthony,
I agree with your method when mounting the range finder directly onto a scope, but I was thinking about using it on an NV spotter to get a range to the target before shooting with a thermal rifle scope.
Do you have one of these then? If so a What's your opinion of it?AnthonyR wrote:I just zeroed the laser to the same POI as the scope, no need to see the laser once you have done this.
G
gypo wrote:Do you have one of these then? If so a What's your opinion of it?AnthonyR wrote:I just zeroed the laser to the same POI as the scope, no need to see the laser once you have done this.
G
No I don't have one of these, I had one the old model.
It worked OK but I found it too bulky on the side of my scope so took it off, I found I rarely needed to use it and it was too much of a faff when I did.
Ok thanks for the info
G
G
CustomRifleScopesUK
Gloop wrote:I presume to use this you need to have the ILluminator switched off otherwise you will not see the laser itself pinging on the quarry?
Sorry in the late replies as away on crimbo holiday,
No you can see the laser ping even with the IR torch on, as long as it's not set to white out !
Hope this helps....Splatty
