Wanted: PULSAR L808 IR LASER
silent knight
Post by silent knight » 22 Nov 2012, 19:38
As above, looking for a PULSAR L808 IR LASER. Drop me a PM if you have one for sale.
punky
Re: Wanted: PULSAR L808 IR LASER
Post by punky » 25 Nov 2012, 00:30
hi just thought id let you know the 808s is the same laser with an added lense covering it to stop eye damage,they are all going to be the same now because of health and safty i myself bought a 808s and when the warentee is up i will be removing the coating with a hobby knife :lol:
One life live it!!!!!!
weebster
Post by weebster » 25 Nov 2012, 13:23
punky wrote:hi just thought id let you know the 808s is the same laser with an added lense covering it to stop eye damage,they are all going to be the same now because of health and safty i myself bought a 808s and when the warentee is up i will be removing the coating with a hobby knife :lol:
What kind of coating is it?......kind of stick on film or another lens?
punky
Post by punky » 25 Nov 2012, 14:11
hi what the shop said before i bought mine its just a stick on plastic job one of the members on here said its the same on the ir laser on the digi pulsar scopes,the message was on another forum it said run a modlers knife round the edge of the lense then peel it off and clean the remaining glue off job done
rocket launcher
Post by rocket launcher » 25 Nov 2012, 20:04
the l808 is £180
the new L808s is £110
and my mate at the shop said there are the same ''they are not'' hmm we will make a new variant and lower the price by a third
If you want an l808 i would get one sooner rather than later.
New laws about eye safe lasers have come into force in the states which means Thomas Jacks can not sell the l808 any more they import for the other sellers in its currant format. it has been changed to the 808s.
s meaning eyesafe, whats left in the old state is what is left there are no more once sold they are gone
The manufacturer have had to add a filters to there lasers which makes them comply with new laser laws
also the laser is now a class lower than it was. by using a differant laser it does have the same case as the outgoing model so size dimentions etc are the same the wavelenth, power etc is not see below
The new laser and filter is already fitted on the n750 digisight and it is this what gives it the more grainy look than using a l808 instead of the inbuilt.the new 808s has also got the grainy look. Removing the filter on the 750 and the l808s makes the laser too bright unless its a very very long distance. it is far too bright for any range under 300 yrds. no one has been able to dim it down a bit and get rid of the grainy picture. compared to the old laser the new one is not as good, could be why it can be offered at a cheaper price
other changes include the wavelenth is 780mm was 808mm (hence name)
the range of divergence is now wider is 3-5-15 was 3-12
the operation time is masivly extended on the new laser now 14 hours was 6. due to the new laser not using as much power its not the same laser as the l808
you pay your money you take your chance if i was buying i would spend my money on the L808, not on something that will never be as good, ohh but the man in the shop says
Pulsar L-808S Laser IR Flashlight
Lens diameter, mm 22
Power, mW 250
Laser class 1 (according to standard )
Range of power adjustment 125-250
Wavelength, nm 780
Range of beam divergence, degree 3.5 ... 15
Power Supply, V 3 (2xAA)
Average operation time with one set of batteries, hour 14
Operating temperature -20 °С ...+40 °С
Dimensions, mm/inch 140x45x52 / 5.5x1.8x2
Weight (without/with batteries), g/oz 160 / 210
Pulsar L-808 Laser IR Flashlight
Lens diameter, 22 mm
Power, mW 250
Wavelength, nm 808
Range of beam divergence, degree 3-12
Average operation time with one set of batteries, hour 6
silent knight
Post by silent knight » 25 Nov 2012, 20:52
Thanks for the info.....
punky
Post by punky » 25 Nov 2012, 21:29
so looks like it was a load ov bull that i was told thanks for giving us the full story
Post by sunndog » 26 Nov 2012, 20:36
rocket launcher, where did you manage to find those specs mate...i couldn't find owt anywhere near as exhaustive as that
so is the filter on the "s" just some 808nm i.r filter?......seems daft to make it 250mw and then have to filter it down
silent knight, have a free bump mate lol
Thermal hunting forum
V8 90
Post by V8 90 » 26 Nov 2012, 20:57
I've removed the eye safe filter from the laser on my N750 & it's "bright" out to around 14 miles :wtf:
I'll try a couple of ideas soon - see if I can tame it a bit :think: :think:
weebster
Post by weebster » 26 Nov 2012, 21:06
V8 90 wrote:I've removed the eye safe filter from the laser on my N750 & it's "bright" out to around 14 miles :wtf:
Guess you'll be needing one of these then :thumbup: http://www.fas.org/man/dod-101/sys/land/row/fh-70.htm
