Variable/Dimmable power using the rotary switch 850nm
NM800 with 800 IC Brightness Control LED Conversion Kit Boxed
Spare Night Master 800 Head - The head for the Night Master 800, Comes with head with lens and bezel
2x Night Master 800 Neck Sections - A spare neck section without an LED
Night Master Spare Tail Switch
Spare on/off switch
spare o-rings/rubbers
Night Master 18650 extension tube
High Scope Mount
Led removal tool
NO Batteries or charger
This is the new conversion kit for converting a standard NM800 or XSearcher model to the Night Master IC (Intensity Control) model with rotary dimmer switch and IC LED.
This upgrade will allow you to quickly reduce or increase the beam intensity, simply by twisting the rotary switch left or right. This is useful when you need to quickly adjust the beam brightness while hunting.
Whenever you select a new brightness level, it will immediately be memorised by the rotary tail switch and will activate at the level whenever you switch off and on again. The brightness level will be stored to memory until you select a new brightness level or unscrew the tail-cap to remove and charge the battery.
£150 posted uk
Now £140 posted uk
Listed on other sites.
