Some bloke spotter - now £220 SOLD
Post by some bloke » 29 Mar 2015, 20:55
This has an F1.8 prime (fixed mag) 50mm M42 SLR lens - which relates to about 3.5mag if it were a scope.... so not suited to close range ratting for example. (I can supply a C mount lensed spotter that can have smaller lenses fitted for ratting)
Fixed mag and wide lenses have much better light transmission than CCTV zoom lenses at anything above minimum zoom - which makes them much more useful for ambient light performance that is beneficial for covert spotting. Image
https://www.youtube.com/watch?v=lcUlDE_ ... -OWKFJadkw
No expense is spared on my standard spotter builds - only the very best E700 camera is used rather than some of the budget clones that seem to use cheaper but similar sounding second or third grade sensors. The long neck of the camera body has the 'some bloke' improvement - it is milled back to ensure all of the nice wide lens rear glass element see's all of the CCD sensor:
It comes with a solid rod handle that can also be slipped through a bush in a dummy sunroof perspex plate like this:
https://www.youtube.com/watch?v=3oK2M-G ... -OWKFJadkw
Or with the screen re-located inside your shooting truck - this one is fixed with a camera suction mount and has a DVR velcro'd to the side of the custom made battery/monitor pod:
You can expect to see this image quality on a night with decent moon & scattered clouds But with a larger field of view because this was done with a 75mm lens - also F1.4:
And this is the massive help you get from a quality camera equipped spotter when its foggy:
This is how you remove the monitor to change the batteries after three hours constant run time if they are quality 18650 cells:
https://www.youtube.com/watch?v=IliQEYhBqJk
Price reuction £220 - no batteries supplied.
Re: Some bloke spotter - now £220
Post by some bloke » 01 Apr 2015, 16:50
I'm getting some better deals these days so I can reduce the price of them:
Now only for a genuine E700 equipped spotter at £220!
master tech
Post by master tech » 01 Apr 2015, 20:03
yes please how much for the postage to northumberland?
Post by some bloke » 01 Apr 2015, 23:36
master tech wrote:yes please how much for the postage to northumberland?
A tenner usually covers RMSD thanks MT. :thumbup:
I'll PM you my paypal addy to expedite matters. :angel:
Re: Some bloke spotter - now £220 SOLD
Post by some bloke » 03 Apr 2015, 03:13
Sold to master tech.
