As Title Ive got an Ultrafire RL2088
Im thinking it might be a good IR conversion it has an Osram CREE on a std Osram star pcb so shouldn't be to hard to change
so would need an Aspheric lens the OD of the flat one is 46mm with 41mm showing thru the bezel
ATB
Duncan
Wanted 46mm Asheric lens
Dorset Woodland Blades: 'I see you've played Knifey Spoony Before'
Re: Wanted 46mm Asheric lens
You can sand the lens down to fit bud. I used a belt sander to reduce the diameter of the 66mm lens in my latest project. Takes time and patients but it can be done.
Marky610 wrote:You can sand the lens down to fit bud. I used a belt sander to reduce the diameter of the 66mm lens in my latest project. Takes time and patients but it can be done.![]()
cheers will try that
grinding down shouldn't be a problem
Well there you go your more than half way there
Take your time because they get bloody hot bud
