Imax br6ac and 18650 and lipo batteries
Torchwood
Post by Torchwood » 27 Jul 2014, 18:13
Long wait for hoby king, but finally got them here. A bit confusing with all leads. Need to charge 18650 batteries, I have a twin serial holder. Any ideas on the setting I should use? How about the blue battery pack from el wirecraft, what's the setting on those?
Looks a solid charger, just need to learn how to charge and discharge these batteries.
Toni
AirRifleSport
Re: Imax br6ac and 18650 and lipo batteries
Post by AirRifleSport » 29 Jul 2014, 13:17
Hi Toni, here is a video link for that charger. Hope is of some use. :)
...and I forgot to add it. :oops: :lol:
http://youtu.be/vOJdyaBbosE
Torchwood
Post by Torchwood » 29 Jul 2014, 16:48
Thanks, Im trying to work it out. It's a amazing bit of kit. Would like to do a review soon.
Toni
22-250jock
Post by 22-250jock » 29 Jul 2014, 18:36
watcha Toni
I'm guessing you would have to add balance leads to the elwire battery pack if you wanted to use all the functions on the Imax
I've made up battery packs using 3x 18650's before, with balance leads, and the imax makes sure each cell is charged to the same capacity......you can also discharge them too ;)
info on balance leads http://scriptasylum.com/rc_speed/lipo.html
cheers john
Torchwood
Post by Torchwood » 29 Jul 2014, 19:21
Thanks John, is balancing abslute!
Toni
Post by phoenix » 29 Jul 2014, 21:56
As I understand it, when using the IMax to charge lithium batteries, it expects balance leadsto be connected to it so it can monitor the voltage of each cell.
I wouldn't be surprised if it won't charge unless balance leads are connected.
Clearly the Elwire battery packs don't have balance leads, so it might be necessary to open up the battery pack and solder wires to the protection ciruit pcbs at the appropriate places.
Having said that, the chargers that come with the Elwire battery packs are perfectly OK for charging those packs because the protection circuits on each cell prevent bad things from happening to the battery.
The Elwire packs are designed for low current discharge and low current charging and in that situation balance charging is simply not necessary.
The IMax is primarily designed for charging lithum batteries used with RC models and those battery packs are optimised for extremely high current discharges and have no protection circuits.
In that situation it's necessary to have each cell charged to exactly the same voltage and it takes a balance charger to do that.
AirRifleSport
Post by AirRifleSport » 30 Jul 2014, 08:33
Another great info about batteries and charging methods, Bruce, thanks! :thumbup:
