what sling / shoulder strap for nv thermal range finders etc
thesmi
Post by thesmi » 11 May 2014, 20:43
hello :wave:
what slings are people using to hold there equipment around your necks while out hunting please? i need something but dont want harness type must be sling or neck
Re: what sling / shoulder strap for nv thermal range finders
Post by sunndog » 11 May 2014, 21:15
i use an old yukon ranger strap, the posh neoprene one
overhead style so the unit sits to one side. that way it don't swing back and forth as you walk and sits under me coat quite nicely in bad weather
Thermal hunting forum
Fox Hunter
Post by Fox Hunter » 11 May 2014, 21:31
I use the one that came with the guide, em pulsars, bloody cheap rubbish with no strap :o :lol:
Perhaps a camcorder or camera strap would do the job? That's what I use on one of my nv monos. On my other I use one of those straps that holds those name cards around your neck. It's got two quick release G clip type things either end so it's quick to take off and small in my pocket if I want to use the mono as an add on. Anything does the job for me but personally I prefer a bino pack to slip them into..
Handyandy
Post by Handyandy » 11 May 2014, 22:52
I use an old puppy lead its one of those thin flat strap type. I have a short bolt to the correct thread with a nut and a repair washer and one of those key ring loop things.
Basically the washer has a hole drilled in it, just big enough to get the key ring loop fastened to it, then the bolt is fed through the hole and a plain but is run up to the underside of the washer. The bolt is then screwed in to the threaded hole on the left side of the TI until it bottoms out, then the nut is gently wound back locking onto the body of the TI securing it in place.
The lead has been attached to the key ring loop by the handle end and the bottom end, then a knot has been tied to shorten the strap to the correct length for it sitting comfortably round my kneck.
All in all the total cost was about 2 quid plus the lead that was hanging there doing nothing.
Cheap n cheerful but works a treat. Possibly not the best solution but it works for me as it allows me to have the TI around my neck and tuck it under my jacket if it pees it down.
I'll add a picture or link to a pic once I get the chance.https://www.dropbox.com/s/h3ta4lvpekjoj ... 013901.jpg
Gloop
Post by Gloop » 11 May 2014, 23:08
Having tried a few options I ended up with a harness under my coat. I know you don't want a harness but it works so well. I usually walk around with my coat 1/2 zipped. It doesn't bounce around because it is held tight to the body by the elastic harness and can be stuffed away for climbing gates etc.
I just couldn't get on with a strap. Swung everywhere and I use the thermal so much of the time.
Post by PESCA » 11 May 2014, 23:14
For a 38s, my chest or breast pocket. Hate stuff sloshing about.
punky
Post by punky » 11 May 2014, 23:18
I just use a boot lace with a knot in it through the bresser strap round me Gregory long another so it goes in my sky rocket :lol: :lol: thinking of getting a proper para cord one soon though they have them on eBay :thumbup:
One life live it!!!!!!
fizzbangwhallop
Post by fizzbangwhallop » 12 May 2014, 12:43
As per George, I like to shove mine into the chest bino pocket on the Rivers West smock but I bought these in case I missed it in a rush to get out and chase foxes around the countryside...
http://www.ebay.co.uk/itm/251391245671? ... 1497.l2649
And one of these.......
But he's now not showing any for sale.... :eh: Might be worth sending him a message, or just do a search for "paracord lanyard" - just tried and several options come up.
I also bought a couple of the large neoprene lens cases from 7dayshop for the 14 and the 38S - easier to slip into a pocket than the supplied case...... Billy Bargain! They're on offer.
http://www.7dayshop.com/7dayshop-neopre ... 5lb3ByZW5l
8-)
rodp
Post by rodp » 12 May 2014, 18:15
fizzbangwhallop wrote:As per George, I like to shove mine into the chest bino pocket on the Rivers West smock but I bought these in case I missed it in a rush to get out and chase foxes around the countryside...
8-)
Didn't you like the first one then ? :roll:
Post by sunndog » 12 May 2014, 18:52
well he needed one for BOTH ears now didn't he! :D
