Computer genius urgently needed !!!
rodp
Post by rodp » 27 Dec 2013, 14:47
Anyone a little bit good on PC's up for a challenge? We run two PC's networked on a Virgin superhub thingy, both wired. This one is dying rapidly, it's old, full of rubbish and probably riddled with ricketts.
The other one, empty, formatted, set up with XP, will just not connect to the internet :(
No matter what I run or do it just will not connect. I ran the IE diagnostic and had miles of text about proxys etc :crazy: . Means nothing to me. It will connect to the other pc so something's working :thumbup:
Anyone care to take a look at the diagnostic list ?.................Please :thumbup:
jdk1
Re: Computer genius urgently needed !!!
Post by jdk1 » 27 Dec 2013, 15:20
rodp wrote:Anyone a little bit good on PC's up for a challenge? We run two PC's networked on a Virgin superhub thingy, both wired. This one is dying rapidly, it's old, full of rubbish and probably riddled with ricketts.
Rod it was a long time ago i got a new one but i'm sure i downloaded a lot of different settings and what have you onto a cd or flash drive from the old one and just put it onto the new one , it must have been really easy as i know bugger all about them :oops:
rodp
Post by rodp » 27 Dec 2013, 15:29
Done that John, well, copied everything over manually. Double checked addresses, numbers, the lot. The computers connect to each other and the one that won't connect apparently "pings", just will not connect to server.
I've reached the end of my capabilities (didn't take long) and it needs someone with a little know how now.
If there's no joy on here I'll cart it off to a shop and get them to take a look.
I think it's going to be one of those "who did this, dumbass" sort of things :oops:
Thanks anyway John :thumbup:
snu
Post by snu » 27 Dec 2013, 15:48
Rod, have you loaded the driver for the network adaptor, chek under control panel, then device manager see if you have any red crosses, if you do the you will need to reload the driver.
paulham
Post by paulham » 27 Dec 2013, 15:55
Rod if its not the driver thing then PM me your number and ill give you a call in a bit. We were messing about with ip adresses and stuff last week. I've got an idea what it might be
Post by sunndog » 27 Dec 2013, 15:59
Have you tried turning it off and on again :ugeek:
Sent from my GT-P1000 using Tapatalk 2
Thermal hunting forum
rodp
Post by rodp » 27 Dec 2013, 16:04
Hi Snu, 2 network adaptors !! One 1394 netadaptor and one Inte(R)PRO/100VE network connection ???
It says all network adaptors / drivers etc OK :crazy: No red crosses
Paul,may have to do that mate :thumbup:
rodp
Post by rodp » 27 Dec 2013, 16:07
This is what the diagnostic says
Last diagnostic run time: 12/27/13 13:35:44
Gateway Diagnostic
Gateway
info
The following proxy configuration is being used by IE: Automatically Detect Settings:Enabled Automatic Configuration Script: Proxy Server: Proxy Bypass list:
info
Could not get proxy settings via the Automatic Proxy Configuration mechanism
info
This computer has the following default gateway entry(ies): 192.168.0.1
info
This computer has the following IP address(es): 192.168.0.4
info
The default gateway is in the same subnet as this computer
info
The default gateway entry is a valid unicast address
info
The default gateway address was resolved via ARP in 1 try(ies)
info
The default gateway was reached via ICMP Ping in 1 try(ies)
warn
Hostname www.microsoft.com could not be resolved (Error code 0x2afc). Could be either gateway or DNS issue
action
Automated repair: Renew IP address
action
Releasing the current IP address...
action
Successfully released the current IP address
action
Renewing the IP address...
action
Successfully renewed the current IP address
info
info
info
info
info
info
warn
action
Automated repair: Reset network connection
action
Disabling the network adapter
action
Enabling the network adapter
info
Network adapter successfully enabled
info
info
info
info
info
info
warn
action
Manual repair: Reboot modem
info
This computer has the following default gateway entry(ies): 0.0.0.0
warn
There is no default gateway entry
info
Waiting some time for the modem/router to stabilize
action
action
action
action
action
info
info
info
info
warn
The default gateway address could not be resolved via ARP
info
Redirecting user to support call
IP Layer Diagnostic
Corrupted IP routing table
info
The default route is valid
info
The loopback route is valid
info
The local host route is valid
info
The local subnet route is valid
Invalid ARP cache entries
action
The ARP cache has been flushed
IP Configuration Diagnostic
Invalid IP address
info
Valid IP address detected: 192.168.0.4
Wireless Diagnostic
Wireless - Service disabled
Wireless - User SSID
Wireless - First time setup
Wireless - Radio off
Wireless - Out of range
Wireless - Hardware issue
Wireless - Novice user
Wireless - Ad-hoc network
Wireless - Less preferred
Wireless - 802.1x enabled
Wireless - Configuration mismatch
Wireless - Low SNR
WinSock Diagnostic
WinSock status
info
All base service provider entries are present in the Winsock catalog.
info
The Winsock Service provider chains are valid.
info
Provider entry MSAFD Tcpip [TCP/IP] passed the loopback communication test.
info
Provider entry MSAFD Tcpip [UDP/IP] passed the loopback communication test.
info
Provider entry RSVP UDP Service Provider passed the loopback communication test.
info
Provider entry RSVP TCP Service Provider passed the loopback communication test.
info
Connectivity is valid for all Winsock service providers.
Network Adapter Diagnostic
Network location detection
info
Using home Internet connection
Network adapter identification
info
Network connection: Name=Local Area Connection 2, Device=Intel(R) PRO/100 VE Network Connection, MediaType=LAN, SubMediaType=LAN
info
Network connection: Name=1394 Connection, Device=1394 Net Adapter, MediaType=LAN, SubMediaType=1394
info
Network connection: Name=Internet Connection, Device=Internet Connection, MediaType=SHARED ACCESS HOST LAN, SubMediaType=NONE
info
Ethernet connection selected
Network adapter status
info
Network connection status: Connected
HTTP, HTTPS, FTP Diagnostic
HTTP, HTTPS, FTP connectivity
warn
FTP (Passive): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
warn
HTTP: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
warn
FTP (Active): Error 12007 connecting to ftp.microsoft.com: The server name or address could not be resolved
warn
HTTPS: Error 12007 connecting to www.microsoft.com: The server name or address could not be resolved
warn
HTTP: Error 12007 connecting to www.hotmail.com: The server name or address could not be resolved
warn
HTTPS: Error 12007 connecting to www.passport.net: The server name or address could not be resolved
error
Could not make an HTTP connection.
error
Could not make an HTTPS connection.
error
Could not make an FTP connection.
rodp
Post by rodp » 27 Dec 2013, 16:08
sunndog wrote:Have you tried turning it off and on again :ugeek:
Only a dozen times :thumbup: (it is easy to forget the simple things though, I'll give you that)
snu
Post by snu » 27 Dec 2013, 16:40
Rod, type this into the search engine and see if it come up with Goggle "64.233.161.104"
