Evnin all.
Just joined the forum and notice few a old faces.
Just started looking at NV. Baz has saved me a lot of leg work cos he's been doing it for a bit.
Want to make some cheap add'on stuff.
Im not botherd about having a big screen on top/side of gun. May as well have a beacon on. I want something to "look through" more or less.
Im to poor to buy owt, so i'm forced into a diy setup.
Like the look of the bullet cams. but need them to be focusable. And need a small view screen. can machine sommet up to cobble it all t'gether.
Al probly give every thing a few coats of looking at before i make owt.
Anyhoo. See yuz later.
Sean.
eyup
Re: eyup
Well that's what it's all about-sharing ideas.
To be honest, most of it is modular, in as much as you match this to that until you get the picture, size, position you want. At that point you can then say 'okay, now if I made this to fit that properly, with a bracket there' and end up with your finished item.
We're not all looking for the same thing. Some want a spotter, some an add-on, some a dedicated.
The hard part is the expense that you can lay out in trying different things. Cameras, lenses, monitors, dvr's. It all adds up, but hopefully, you'll eventually hit on the right combination (and that's the jackpot).
Bottom line, if someone tries something and it's good, then say so. If it's rubbish, then say so. That way, someone else doesn't go out and buy the same rubbish as you. Share your ideas.
silent shooter
- FOUNDER
Re: eyup
Hi Sean realy pleased you joined mate,the barrel you blued and screw cut for me was spot on.
Hope your keeping well and happy new year to you and your family
Geoff
Geoff
Re: eyup
Hello bud.
Good to see someone like yourself on here, maybe able to put something as professional looking together as you do for the Rapids and the like!
look forward to seeing your creations
.177, Carbon Shroud, Anschutz Adjustable trigger, Quickfill & Gauge with Elite 4200 6-24x40
http://i1120.photobucket.com/albums/l49 ... ab00b1.jpg
