After dark we set out to look at a few rabbits, I knew for a couple quite local so we parked the quads and went on foot. Through the nv I spotted a pair of eyes roughly where I knew 2 rabbits had been feeding so Declan looked through the thermal. He then passed it to me and said take a look, I didn't really know what to expect as I knew the eyes were right by a patch of fern. As I looked through the thermal I could see about 15 other heat sources I'd missed in the cover with the nv, they were sheep
The foxes are pretty thin on the ground here so we went to a neighbours where we 'should' be guaranteed some action. I was scanning with the lamp as we had quite a bit of ground to cover and with so many heat sources about it would have taken too long to do it with the thermal or nv. With the lamp we spotted a fox a fair way in the distance but it was surrounded by sheep so wasn't 100% on ID. I zapped it with the range finder at 262M and gave a little squeak but this fox was one that seemed content to stay exactly where it was over the bank out of the wind so Declan got on the nv mono. The fox was behind a tump (bank,rise,lump) where the breast was covered in fern, luckily the fern's late this year so it's not up to your neck yet but it made it really difficult for the nv. I was looking through the thermal but struggling to see exactly which heat source was the fox as sheep hidden in the fern and rocks from the day's sun were also showing up along with the fox somewhere in the middle. Declan decided he just couldn't see enough with the nv so I said I'd just shoot on the lamp. I got into position but could hardly make out jack through the scope. At this range the Z6 is usually perfect so being so knowledgeable and obviously knowing more than a range finder
Declan was obviously holding the lamp and spotted the fox further down the bank but disappeared through the fern, I'd missed like a tw@t and the round had gone over the top of the fox
Anyway, back to the thermal..
I think in the right place you could manage with a thermal instead of a spotter, like where it's all grass, crops etc. What we found up here though was as there are so many sheep and other heat sources from rock's ect it makes spotting stationary foxes extremely difficult. I definitely want one but Declan kindly said he'd call back later in the year when it was cooler so I could see the difference so I'm going to hold off the purchase for a while. We both came to the conclusion that for spotting it was so much easier with a lamp if you wanted to cover a large area but if I was stationary waiting you'd obviously get to know which heat source was staying put although you'd definitely also need an nv mono. It also showed me what the thermal actually picks up that you can't see with the nv which was extremely impressive. So to sum up I wouldn't say thermal is THE answer here but as part of an arsenal it definitely has benefits and a place. You need to use your non shooting eye to view through it as you loose your night vision more than from nv. Even looking through nighvision after the thermal seemed dark so I can see a big benefit in using an additional screen with a thermal if it would help keep your nightvision better.
I've babbled and gone on and could have kept on but I'll leave it there and add to it if I think of anything later.
So a big thank you Declan, it was great to meet you, see the thermal in action and to also see you pass your grade 1 quading. Don't forget grade 2 in the winter mud,muck,rut's and ice
