Think about it
If you were to be asked, right after a perfect hit on a 200 yard fox what you did, I bet you could not give a definitive answer of the sequence of events.
For instance, you're looking through the scope with the target in sight - what happens next, how did you get to that point ?
How does your brain process the image and then decide when the shot is to be squeezed off.
A percentage of shots in the field are not taken in ideal body positions or circumstances.
Shooting paper targets off a rock solid rest (on the face of it) can be seen as a technique which differs from this in as much as you have time, you can adjust your positioning until you are comfortable -is it though ?
Fir instance, what does YOUR eye concentrate on -
1, alignment of the crosshair to the target
2, alignment of the target to the crosshair
How do you do it, how did you get there - target aquisition, rifle mount, and the shot....the whole shooting match
H
