ATN X-Sight 4K Pro and ABL rangefinder
Broadside
Post by Broadside » 18 Oct 2019, 07:05
Hi.
I use an ATN X-Sight 4K Pro 5-20 on an FAC FX Impact. I've just invested in an ATN ABL laser rangefinder so I can exploit the ballistic calculator function. I've zeroed the ABL at 50m and most of the time it works great. Press the button and the range finding reticule appears in the middle of the screen and the flashing laser in the middle of that. However, sometimes the flashing laser light appears outside of the reticule. I've found the only way to make it behave again is switch the X-Sight off and on again. Whilst its not a problem at night because I can see when the laser is not centred, during daylight, when the laser is not visible and I rely on the rangefinder reticule, I could be way off.
Has anyone else experienced the same issue and have any ideas whey this is happening and what can be done to fix it? I have the latest firmware update.
Thanks all...
