Any Sign makers, vinyl lettering men on here ?
Right men, been asked quite a few times (lots) over the last couple of years for lettering on jobs, always put it off because we supplied sign makers with blank banners and it would be a conflict of interests.
However, local vinyl supplier now does blank banner material "off the roll", cheap and Chinese but it does the job. Obviously a lot of the sign makers now use this.
So, I've bought a vinyl cutter and a load of vinyl, just need a cutting program now. After something relatively cheap, simple to work and reliable. We've no intention of doing complex graphics just fonts and the odd shape (moon / stars etc). I used to use one ages ago so know how to operate it, sort of.
Any recommendations for a cutting program, cheap, reliable, simple ?
- fizzbangwhallop
Re: Any Sign makers, vinyl lettering men on here ?
Looks like a ''No'' then Rod?
fizzbangwhallop wrote:Looks like a ''No'' then Rod?![]()
Looking that way Fizz
It's only an add on to the core business so not the end of the world if it goes pear shaped
Rod.
Don't know a great deal about programs for cutting out vinyl lettering myself etc. but I do give some freebee logs to a friend who owns a printing and graphic sign making company. I can easily call a favour in as long as you give me a pecking order of what vinyl cutting program you are looking for ?, or is it easier for me to find out what makes and models of machines they are running and what compatible cutting programs might be available that would suit you etc. Let me know and I will do a bit of arm twisting
Phil
Cheers Phil, running a Creation Pcut cto 630, or trying to
Just be good to know what's a good, cheap, reliable program for text and simple shapes.
Ran a cutter and printers a while back now but we used an expensive program as we were printing truck side curtains, therefore it was worth the cost.
Thanks buddy
Thanks buddy
Rod I will call with my vinyl cutting friends on Monday and you will know some answers by Monday night O/K. Phil
Cheers Phil
Rod have a look at http://forum.uscutter.com/index.php?/to ... ion-ct630/
Copied below is a post off the above forum.uscutter, "I am on the case already
Members
PipPipPip
Posted 31 October 2011 - 06:42 AM
first off, Artcut is not a very good design/cutting software to use. Many complaints from users. They usually switch to Signblazer , which is FREE design/cutting software that can be downloaded here on the forum.
There is also a great Newbie manual, created by a forum member, that can walk you thru the process of setting up your cutter, Download in first post. Hope this helps.
http://forum.uscutter.com/index.php?/to ... first-cut/
SignBlazer is both a design and cutting program, all-in-one, and also works well. But, if you are already really good with Corel, then I would opt for SignCut so you do not need to learn a new design software.
Members
PipPipPip
Do you do one piece vinyl suits ? or has Fizz monopolised the market........
hairyyoda wrote:Rod have a look at http://forum.uscutter.com/index.php?/to ... ion-ct630/
Copied below is a post off the above forum.uscutter, "I am on the case already"
Members
PipPipPip
Thanks Phil. It's right in saying Artcut isn't a lot of cop, it can have problems, and I believe it hasn't been updated since 2009. Trouble with signblazer is that the bloke died before it was finished properly (damned inconsiderate of him ) and there can be problems with it on non Uscutter machines, worth a shot although there's no support now. Sign Cut I think costs a bomb.
A lot of these cutter programs can be a pig to get up and running which is why I was after someone with experience to say "yep, limited program but easy to set up and use" ............ or not
I'll have a look at the newbie manual and see what the crack is
Oh, seen the Haflinger on ebay? Up to 1650 ish at the mo
Must repeat, "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger" "I don't need a Haflinger"
It's not working
