Help with mount fittings!!
Torchwood
Post by Torchwood » 11 Jan 2015, 13:09
Need to identify the mount base on these, removing the scope is not a option.
Is it weaver or dovetail?
Toni
Re: Help with mount fittings!!
Post by phoenix » 11 Jan 2015, 13:36
The CZ527 has 16mm dovetail grooves on the receiver, so neither normal 9-11mm dovetail rings or weaver rings will work
Sportsmatch make scope rings to fit that size of dovetail.
Davie_M
Post by Davie_M » 11 Jan 2015, 15:48
Cz527 are a 16mm dove tail as said above sportsmatch and warne and kozap do mounts also check opticks ware house http://www.opticswarehouse.co.uk/catego ... ope+Mounts
i have sportsmatch high on mine with a 56 mm nightforce scope
What is it you are looking for
Torchwood
Post by Torchwood » 11 Jan 2015, 16:32
Need a high mounts. Would these work?
Don't know the age of riffle!
Toni
Post by phoenix » 11 Jan 2015, 17:13
They'll work fine - I think all CZ527s have had the same size dovetail rail since they started making them
Torchwood
Post by Torchwood » 11 Jan 2015, 17:55
Thanks Bruce.
Will be mounting the broom on it. Just wondering on the kick back! Do I have to make the internals shock resistance? Would the eyerelife be long enough not bust my eye?
Every day is a new challenge!!
Toni
Post by phoenix » 11 Jan 2015, 18:22
Sorry Toni, i can't answer either of those questions - you'll just have to try it and see.
jdk1
Post by jdk1 » 15 Jan 2015, 21:11
I dont know if these would be any good to you toni
http://www.airgunbbs.com/showthread.php ... ope-mounts
