el wirecraft battery run time advice
hywel1984
Post by hywel1984 » 03 Dec 2014, 21:18
Does anyone have a rough estimate of the run time I would get from an 1800mAh battery and a 2800mAh battery from elwire craft in a spotter build
Firstly if its running a 5" monitor and e700 camera
And
Secondly if its running monitor, camera and T20 torch
I've heard the elwire craft batteries are more stable and closer to their stated capacity than the blue Chinese batteries. I also like the fact they don't have an on/off switch on the battery as this makes saves panel mounting an on off switch in a spotter build
Thanks for any help
Torchwood
Re: el wirecraft battery run time advice
Post by Torchwood » 13 Dec 2014, 13:15
I use only 1800mah batteries. Runing a camera, screen and torch around 3hours.
Toni
hywel1984
Post by hywel1984 » 14 Dec 2014, 00:04
Thanks, I've bought a 2800mAh battery. It should be more than enough for a full nights shooting then.
Torchwood
Post by Torchwood » 14 Dec 2014, 08:59
2800mah can run a screen torch and camera for over 4 hours continually. If used with a spotter, you will get a lot longer.
Toni
