Different scopeless design
Snapper
Post by Snapper » 15 May 2014, 17:10
I've been thinking about a scopeless build pretty much as soon as I finished my add-on. I had ideas about ali tubing, tapping cutting drilling etc but a new, simpler idea has presented itself.
I bought a second hand cctv camera from ebay (total of £12.50) with a view to using the 12.5-75 mm f1.8 lens and binning the rest. It turned up today and I was initially a bit disappointed as it is bigger and heavier than I had hoped, but when I had a look inside the metal camera body I discovered it was almost entirely empty save for the board cam (a 1/4" Sharp thing, now binned), which gave me the idea that I could just replace the camera and fit a viewfinder and 12 v battery into the void - which should just fit snuggly.
It will also mean that I don't need to faff with ways of securely attaching the camera or lens as it has already been done for me, and the total length should still be less than a rifle scope. My plan is to use matt black heat-shrink tubing on the lens so that the zoom ring is held in place (obviously i won't put it on the focus or aperture rings).
I'm hoping the total cost shouldn't be too much more than £60 as I'm going to use the same cheap Effio e board cam that I used for my add-on as I'm mightly impressed with that one.
grantellissheffield
Re: Different scopeless design
Post by grantellissheffield » 15 May 2014, 17:41
should look good when finished in a coat of black.
genisis22
Post by genisis22 » 15 May 2014, 18:39
looks like a plan, and I am sure you have already thought about mounting, couple of mounts with top ring of, very low profile should do the trick nicely using original cap nuts down through to mount bottoms after some careful lining up, you could elongate the holes to give some lateral leigh way for final alignment to bore.
Torchwood
Post by Torchwood » 16 May 2014, 16:45
You can have it look like this maybe.
Snapper
Post by Snapper » 16 May 2014, 17:16
I'm going to use a camcorder viewfinder again and a board lens so it won't be quite like that. What lens is yours and is it any good? Mine is marked Sony but underneath it says made by Tamron.
When I get the bits together (and when I get an OU exam out of the way) I will put up a full account.
Torchwood
Post by Torchwood » 16 May 2014, 17:45
Its a mint canon lens. Optics really clear, just turn up today, havent tested it at night yet. But 1.8 apperture must be usefull.
Toni
Snapper
Post by Snapper » 27 May 2014, 22:29
Here's a quick preview of my build so far. The viewfinder will have to be a couple of inches longer but it is almost there.
I will do a full write up when its done.
Torchwood
Post by Torchwood » 27 May 2014, 22:43
This is interesting, it's getting better all the time, it looks the part, anxious for the full review. :thumbup:
22-250jock
Post by 22-250jock » 28 May 2014, 06:49
looking good mate :thumbup:
gypo
Post by gypo » 28 May 2014, 08:30
Looks good mate, well done
G
