Drone Pro x 10 for sale - £1400
Selling this because I've been totally thermal for a while now and it's not getting used.
Purchased new from Carl Moore about 3 years ago.
This is the pure x10 model (no doubler) colour screen and OLED display
In full working order,but has some very minor marks on the body through normal use.
Drone Pro x10
Drone Pro x10
Re: Drone Pro x10
If I hadn’t got two already I would have had this.. Bruce absolutely fantastic bit of kit heads up for this
Regards
Colin
Regards
Colin
Chrissmith0881
Re: Drone Pro x10
Don't want to mess up your post but what thermal do you use to warrant getting rid of the drone? I use a drone and love it.
Re: Drone Pro x10
I use the equivalent of a WT1-75-6 (640 sensor/75mm lens).
That's the same spec as the roof mounted thermal spotter I use.
Using a spotter and scope with the same magnification and field of view as each other makes target acquisition with the scope easy because what I see on the spotter screen is exactly the same as I see through the scope. Once I have acquired the fox with the scope, I can use digital zoom to enlarge it's image and make the shot easier.
The Drone Pro is a fantastic piece of kit - I shot a load of foxes with it. However, there were several occasions when I didn't get a shot at a close range fox because it had gone before I acquired it due to the Drone Pro's much narrower field of view.
I was in the very fortunate position to be able to buy some top end thermal kit, otherwise I'd still be using the Drone Pro.
