armsight atam000008 external battery pack
rusty53
Post by rusty53 » 04 Apr 2018, 13:49
wanted drone pro external battery pack
Re: armsight atam000008 external battery pack
Post by phoenix » 04 Apr 2018, 16:11
I see it's your first post, so let me enlighten you.
Nobody uses the external battery pack because it's ridiculously expensive, and virtually unobtainable.
Make an external battery pack using a 6 cell AA battery holder with one cell holder shorted out and 5 AA rechargeable batteries will give you the 6 volts you need.
There are other alternatives using 2 x 18650 lithium rechargeable batteries, but this will require a voltage regulator to get the voltage down to 6 volts
Alternatively, stock up on Panasonic CR123a non rechargeable batteries - buy them in bulk and they cost around £1 each.
Finally, only switch the scope on when ready to take the shot.
rusty53
Post by rusty53 » 04 Apr 2018, 16:28
Hi Bruce thanks for that info its for my brothers drone i will pass that on to him
WillC
Post by WillC » 06 Apr 2018, 06:44
If it helps I followed the advice from Bruce, built it and it works a treat.
Regards Will
rusty53
Post by rusty53 » 06 Apr 2018, 07:51
Hi Will is there any way you could send me a picture .Thanks Antony.
Keefer
Post by Keefer » 08 Apr 2018, 08:56
I’ve got one if you are still up for one £100 delivered with 2flat top Panasonic batteries
Keefer
‘‘Tis better to have Droned and lost than never to have Droned at all :-)
rusty53
Post by rusty53 » 09 Apr 2018, 08:21
Ok Keefer I will take it pm inbound
Keefer
Post by Keefer » 09 Apr 2018, 10:26
Ok bud got pm will reply with details after work thanks
Keefer
