Looking for an add on for rimfire and center fire
muntjackdjb
Postby muntjackdjb » 08 Dec 2017, 22:24
Hi as title. Been using a photon xt extreme but I need nv on several rifles. So any advice would be good also wondered what you guys may have for sale.
Regards Dan
Mini Magnum
Re: Looking for an add on for rimfire and center fire
Postby Mini Magnum » 08 Dec 2017, 23:55
Ward 800
Miki
Postby Miki » 09 Dec 2017, 10:59
Mini Magnum wrote:Ward 800
Are you saying that's what the OP should buy or that you have one for sale ?
Postby warbucks » 09 Dec 2017, 12:59
Hi Dan.
Advise.
You will have found out with the photon extreme that finding quarry in the first place is hard due to the narrow field of view, here a "good" n/v add on system will beat it as you can locate the quarry on say 3/4 mag, then once on it mag up to 12 or more with still as good as or better picture than the photon.
If you can get on with t/v type screen then the EVO n/v add on that "some bloke" on here sells will give you the range of the Wardy n/v, for a lot less money.
Ive been buying and using several night vision's over the last 10 years and i have spent 1,000's of pounds on them, best n/v add on's at the moment are the "Wardy"700/800, i have the 700, ive used a 800L, and to my eye's its no better than my 700.
My advise, buy either a good second hand 700 (these's go for around £500) or a second hand or new 800.
Postby some bloke » 09 Dec 2017, 13:17
muntjackdjb wrote:Hi as title. Been using a photon xt extreme but I need nv on several rifles. So any advice would be good also wondered what you guys may have for sale.
Regards Dan
How deep are your pockets - and have you always 'looked through' a near eye device or seen a heads up monitor device like the one in my photo below or the nightsight - or some of the crude rubber pipe one's from the bottom of the barrel on ebay that have the monitor too close to focus on properly?
muntjackdjb
Postby muntjackdjb » 09 Dec 2017, 15:50
I don't like the big screen type. So wanted an in line type.
Postby some bloke » 09 Dec 2017, 16:08
muntjackdjb wrote:I don't like the big screen type. So wanted an in line type.
That about limits your choice of an add on to a used NT300 (one on the bay) or a WDV.
muntjackdjb
Postby muntjackdjb » 09 Dec 2017, 16:26
Which would be your choice?
What about tubed ?
Regards Dan
Postby some bloke » 09 Dec 2017, 16:50
My little experience of tubed add on required a longer more flexibile neck than I have - and eyes further away from my nose might have been helpful too. :D
Postby phoenix » 09 Dec 2017, 17:01
What about tubed ?
Regards Dan
Forget tubed unless you can afford a front add-on (PVS27), otherwise it's a WDV 700 or 800
Return to “Sales and wanted items, swaps, e.t.c”
Users browsing this forum: No registered users and 21 guests
