Hi Guys,
I have made a breakthrough it getting every thing into one vf-c2
It is now tested on a .308 calibre rifle for recoil and vibration with the potting compound ( not even a flicker )
Your VF-C2 will forever be protected from spikes and the weather !
I have managed to install with it the 5v regulator that will protect it and allow for up to 42v input
I have also installed the voltage On screen display with timer and signal loss indicator
This also comes with a rotary pot switch that you can mount where you want, it dims the brightness of the screen and turns the unit on/off
All these extras plus my work including VF-C2 = £165 +P&P
Oh and before i forget, you get a free schematic on how to wire it in with the rotary switch as well
The OSD you will see when looking through the viewfinder, never get caught out with no battery power again, also has built in timer !
Let me know if you want one made for your build !
Kind regards Splatty
