Ward D Vision 800 - Further improvements
Post by cliveward » 16 Mar 2017, 17:25
Hi All,
I've been a bit quiet recently on 'internetland' and will be for a little while yet. Aside from being away on business recently and then contracting 'consumprion' (but is actually just a cold according to the War Dept.), things are afoot again with improving the WDV. :thumbup:
We are changing from a moulded housing to a CNC machined housing. This will make the unit stronger and more precise.
The downside is that the original CAD files are for an 'additive' process and they have to be completely redrawn for the new 'subtractive' process which has been a bit of a mission. The good news is that while I was at it, I though I might as well make the WDV 'perfect'. I've redesigned the DSA and clamping arrangement so that the clamp now doesn't foul the bolt on certain rifle and day scope height combinations and can be moved to any position. :thumbup: :thumbup: :thumbup:
Unfortunately we thought we had enough moulded housings to see us through until this was done, but what we have in stock aren't of the quality we need for production so it's been a concerted effort to get this done!.
The 3D design is almost complete, then next week will be a few days with the CNC lot going through the program and making sure it will be able to be made efficiently. Then they will need some time to fit the job in, set it up and then crack on with churning them out and then off to be bead blasted.
Re: Ward D Vision 800 - Further improvements
Post by sunndog » 16 Mar 2017, 17:51
Bead blasted.....does that mean a metal housing?
oslon black drivers
morrisman
Post by morrisman » 16 Mar 2017, 19:37
Blimey, I'm really salivating now for my one.
Post by cliveward » 17 Mar 2017, 11:04
sunndog wrote:Bead blasted.....does that mean a metal housing?
We had explored blasted and then anodised aluminium but the weight premium is 180g for that material.
It is 90% likely that the new housing will be Delrin which is then bead blasted to remove any machining marks and provide a flat finish. :thumbup:
Post by sunndog » 17 Mar 2017, 12:48
yeah was thinking about weight when i asked. never thought about bead blasting plastics before tbh
oslon black drivers
Post by cliveward » 20 Mar 2017, 15:22
Hi All,
Steam coming out of myself and the 3D modelling software has resulted in this:
The clamp can be put in any position and the thumb wheel either side of it. 8-)
Off to the CNC boys and girls now. :thumbup:
Post by blueroll » 20 Mar 2017, 16:28
Can`t see the pic Clive.
Post by cliveward » 20 Mar 2017, 16:38
blueroll wrote:Can`t see the pic Clive.
Hopefully fixed it. :wtf:
rodp
A bad influence
Post by rodp » 20 Mar 2017, 16:50
Can the old 700 be upgraded to this Clive, along with the other gubbins inside?
Post by cliveward » 20 Mar 2017, 21:19
rodp wrote:Can the old 700 be upgraded to this Clive, along with the other gubbins inside?
Hi Rod,
Yes. Everything from the 700 series will be upgradeable to this. :thumbup:
