Laser it torch
Pike25lb
Laser it torch
Post by Pike25lb » 30 Apr 2018, 05:28
It has been mentioned to me about ir lights laser ir that is
I have a t50 and a t67 with ir led they seem ok to me but the t67 is bulky
Are the laser ir really better than the t67 and what is there size like compared
Also what can be recommended for a mid range laser ir of they are that good what do you use
Is the mk2 t67 any better
It's been recommended the pbir and dragon fly
Re: Laser it torch
Post by warbucks » 07 May 2018, 11:58
Hi Pike.
If you have a modern T50, & T67, and your not happy with them, then you really need to be going Dragonfly laser, this is about the same size as a T20-ish.
Lasers however do give problems the L E d's dont, that is you need to keep them dry or you will BURN water marks on them, also you need to keep them clean as any muck on the laser will show in the n/v picture.
Another alternative is a Blacksun "Ruby" pill, a T20 one will give the range of a Normal T67, the down side is they arn't as covert and "can" spook.
I'm not a lover of these's yukon lens torches ie sunranger/pbir.
Pike25lb
Re: Laser it torch
Post by Pike25lb » 08 May 2018, 12:32
Thanks for that info not quite straight forward then
So the ruby pill is there a nother one sure I read there was 2 a ruby and a d8ffrent one that is not as vis8able
