IR torches that are silent to turn on
Spanner
Post by Spanner » 15 Oct 2017, 17:46
What is available I have a NM800 and a Clive Ward T67 but both scare Foxes at close range on still nights due to their noisy tail switches. Can anything be done to make them silent and if not what IR torches are out there that are silent to turn on?
reindeer
Re: IR torches that are silent to turn on
Post by reindeer » 15 Oct 2017, 18:36
The switch on these torches cannot be modified to be silent. I use a modified, silent rat tail switch. Another way to switch on and off without noise is: unscrew the tailcap just as much as needed to switch off. You can then operate the torch by screwing on without any noise.
No fence is too tall.......
weejohn
Post by weejohn » 15 Oct 2017, 18:45
The tail switch on the IC nightmaster is pretty much silent. I have one here.
Spanner
Post by Spanner » 15 Oct 2017, 19:02
Well mine isn't it is noisy. Thanks for the tip on unscrewing will be fine for me. :thumbup:
Spanner
Post by Spanner » 15 Oct 2017, 19:36
Just to add my NM800 is an old one not the IC Model, looked at the retrofit kit but it was £90 or so :wtf:
Spanner
Post by Spanner » 15 Oct 2017, 19:37
Thanks both for the feedback.
Mini Magnum
Post by Mini Magnum » 15 Oct 2017, 20:32
Also laserluchs 5000 is silent toggle switch.
Post by blueroll » 15 Oct 2017, 21:25
Armasight XLRM rotary switch is pretty quiet.
Davesniper
Post by Davesniper » 15 Oct 2017, 21:37
Never had trouble with switch noise I use remote tail on NM 800 but had plenty spook with the red glow ..nowt you can do about that..but then again had them walk in out of quriostity .
Post by some bloke » 15 Oct 2017, 22:28
There's not a lot to be done as you have to use a separate IR torch for most add on rigs - and most use the budget torches with tail cap clicky switches. I don't think that was an issue with the older lasers. It could be worth trying a bit of 1" pipe lagging slid over the rear end to muffle the click a bit.
I use almost silent switches for my integrated torches - one of these if you fancy messing about with your power supply route, they will 'half press' like the tail cap switch for cycling through the power levels:
http://www.ebay.co.uk/itm/On-Off-Latchi ... 2092882727
