Black Sun 2 for T20?
Re: Black Sun 2 for T20?
Post by cliveward » 03 Aug 2017, 14:36
blueroll wrote:I have just acquired a Sunranger based on a T38, which I understand is limited in power due to the pill design (about the best way for us non techy`s to describe it). So the question is can Clive`s new Black sun 2 B22 be modified to become a Sunranger, as I like the fact that there is very little light spill from the Yukon lens.
Yep, I even have some pre machined bezels. If you want to order one just put a note in the comments section of the order and we can supply it without lens and the shorter bezel for you to screw your Yukon lens into. :thumbup:
Chrissmith0881
Post by Chrissmith0881 » 03 Aug 2017, 17:59
What will these be like in a sunranger which already has the black sun pill in it will it be much better?
Post by blueroll » 03 Aug 2017, 18:18
Chrissmith0881 wrote:What will these be like in a sunranger which already has the black sun pill in it will it be much better?
All I can say is that there is a noticeable difference to the AS pill that is in my T38 Sunranger and a BS502 that I got from Clive, so that is why I asked about the new BS22 with the same output being modified to a Sunranger. Hopefully should be pretty good without the bulk/weight of something like a T74.
Cornish fixer
Post by Cornish fixer » 03 Aug 2017, 18:39
Hi Clive have you got any made up bezels to fit on the t20 body to take the Yukon 4/50 lens +how about any of the lens ,do you sell these :eh: cheers in advance
Post by blueroll » 03 Aug 2017, 19:48
Thanks Clive, all ordered and requested bezel in the comments section.
Post by some bloke » 03 Aug 2017, 20:49
I think you may be missing out a decent market by not having any for the EVO type torches yet Clive.
As you can get your own pills made you can accommodate 20mm boards if you omit the cooling grooves in the stock one's. That would be more of an upgrade than intensity alone because some of the internal reflections would also be addressed.
Ooops
Post by Ooops » 04 Aug 2017, 05:04
cliveward wrote:Yep, I even have some pre machined bezels. If you want to order one just put a note in the comments section of the order
How much are the bezels Clive?
marcos58
Location: Manchester, ( by the sea, I wish lol) Lancashire
Post by marcos58 » 08 Aug 2017, 10:50
Hi Clive,
What sort of improvement can I expect from the new Black sun 2 pill in my ranger light ?
Thanks.
Marcos.
Post by cliveward » 08 Aug 2017, 13:37
marcos58 wrote:Hi Clive,
Thanks.
Marcos.
Hi Marcos,
It will be 40-60% brighter depending on what pill and bin of LED you have in there at the moment.
On the ground that should equate to 20-30% more range. 8-)
Also on intermediate ranges if you are getting a decent image from your system at 300 yards, that should then push out to 360-400 for the same quality of image.
marcos58
Post by marcos58 » 08 Aug 2017, 14:22
Hi Clive
Thanks for the reply and information on performance i have just ordered one. I am running my rangerlight with one of your original blacksun pills.
Regards.
Marcos.
