Better quality 16mm lens for e700?
THE GRIFF
Post by THE GRIFF » 24 Oct 2014, 20:21
Anyone know where I can get a better quality 16mm lens from than what comes with the e700 as standard. Looking for a reputable uk supplier, not an exaggerated spec'd one off a foreign eBay seller.
Preferably around f1.2 - f1.4 for my add on build, because of the mirror/prism in the build I want to try and give it as much light as possible so thinking a better lens might be a good place to start, and because jock put a better one in his as well so I am just copying really!
poppy mae
Re: Better quality 16mm lens for e700?
Post by poppy mae » 24 Oct 2014, 20:22
stockoptics.
THE GRIFF
Post by THE GRIFF » 24 Oct 2014, 20:48
poppy mae wrote:stockoptics.
Can't find a low "F" stop one anywhere on the site!
poppy mae
Post by poppy mae » 24 Oct 2014, 20:56
part code BL-D/N-16-350-950nm-1mp F1.4 £25.45 pricy but a big improvement over the standard 16mm lens.
THE GRIFF
Post by THE GRIFF » 24 Oct 2014, 21:23
poppy mae wrote:part code BL-D/N-16-350-950nm-1mp F1.4 £25.45 pricy but a big improvement over the standard 16mm lens.
That ones for a 1/2 inch chip camera which would give a a wider field of view
22-250jock
Post by 22-250jock » 24 Oct 2014, 21:25
Griff
you will have to make sure the stockoptics lens poppy has just linked to, will fit within the top of the mirror casing...,,,if that is how you're mounting it :think:
outside diameter of the lens is 30.5mm
http://www.stockoptics.com/board-lenses ... ormat.html
22-250jock
Post by 22-250jock » 24 Oct 2014, 21:31
as regards the ebay one http://www.ebay.co.uk/itm/370573986988? ... 1439.l2649
bear in mind this was one of the lenses Roland tested, and he found the F number to be as advertised, so I think this seller is one of the honest ones.........
only took 10 days to arrive ;)
poppy mae
Post by poppy mae » 24 Oct 2014, 21:32
Personally think this lens really well on an e700, would say it gives a better picture than there 16 and 25mm c/cs lenses when fitted to the e700,upto you really, Jocks ones, a lot cheaper , but from overseas.
poppy mae
Post by poppy mae » 24 Oct 2014, 21:35
Jock,thought the one you found was a lot cheaper? must be old age.......
THE GRIFF
Post by THE GRIFF » 24 Oct 2014, 21:38
22-250jock wrote:as regards the ebay one http://www.ebay.co.uk/itm/370573986988? ... 1439.l2649
I was hoping to get cracked on with it this week, I didn't really want to wait another couple of weeks as I am away on a course with work, but thanks again, I may resort to having to order the eBay one.
The one from stock optics is for a 1/2 inch sensor and don't really want to alter the field of view because at the momont it it perfect, am I correct in thinking by fitting a lens for a half inch sensor it will alter the field of view of the image?
