Camera mount tube?
gupster
Camera mount tube?
Post by gupster » 27 Jan 2014, 20:54
Hi,
Looking to build my first diy NV setup. Ive ordered a camera similar size to the ej700. Ive seen a few photos of people that have a tube over the rear of the scope which houses the camera. Just wondering what people have been using.
Re: Camera mount tube?
Post by some bloke » 27 Jan 2014, 21:25
I used a piece of car exhaust pipe - me being an old Cornish bloke, likes to things all agricultural like my 'ansum.
Well I growed up near plywood mines see. :thumbup:
22-250jock
Post by 22-250jock » 27 Jan 2014, 21:40
not sure which camera you've got..............................but if its the E700 have a look at paulhams post :thumbup: http://nightvisionforumuk.com/viewtopic.php?f=29&t=5077
gupster
Post by gupster » 27 Jan 2014, 21:41
Thanks so anything that fits then haha. Prob going to find some plastic tubing to keep the weight down.
Cant beat it in Cornwall :D
gupster
Post by gupster » 27 Jan 2014, 21:53
Gone for a cheap alternative, just a board camera without housing. http://www.ebay.co.uk/itm/700TVL-Effio- ... 6350186%26
Once ive had a play with this will then upgrade to a better quality camera.
Post by sunndog » 27 Jan 2014, 21:57
just given myself a wrist slapping for using my secret powers for evil
gupster, what you are after is called a day scope adaptor (DSA).....theres loads of options in the d.i.y section
oslon black drivers
gupster
Post by gupster » 27 Jan 2014, 22:06
Ok thanks. Will have a search around. Saw one that someone had made a carbon fiber look tube. Think the simple tube that hides the camera is quite a neat tidy idea.
22-250jock
Post by 22-250jock » 27 Jan 2014, 22:07
you may also need to think about changing the lens mount to a cs mount http://www.ebay.co.uk/itm/CS-Mount-CCTV ... 19dfa20d91
and change the lens for a 16mm cs http://www.ebay.co.uk/itm/F1-2-16mm-1-3 ... 2c55f4db03
it will help with the quality of the image you get and it easier to mount into a DSA, as the lens body diameter is 30mm ;)
gupster
Post by gupster » 27 Jan 2014, 22:18
Thanks ive got a 16mm board lens coming for it. This one will be just a bit of a test and a cheap setup to play around with then once sussed will upgrade.
koiman97
Post by koiman97 » 27 Jan 2014, 23:42
waste pipe from diy store cheap as chips
