board camera query
Ferrety
board camera query
Post by Ferrety » 18 Nov 2013, 21:47
I've just put a new board camera into my spotter and having a slight problem which hopefully someone can advise me on
Board camera from Aliexpress item model no. SDTX-CD-CO24 700TVL 1/3 Sony CCD Sensor ICX673 +CXD4146+D5148
and I asked them to leave off the IR filter. Image is bright and clear with good detail over 150 m using 50mm Maglite and
6-60mm lens
My problem is that the image on the monitor is reversed which is confusing to say the least. :crazy:
Can this be rectified in any way by using the OSD menu and if so how? or is the camera duff
No comments that I've got the camera in wrong way round as that's already been suggested.
thanks
Geoff :
poppy mae
Re: board camera query
Post by poppy mae » 18 Nov 2013, 22:02
Is there a mirror function in the menu using the osd?
poppy mae
Post by poppy mae » 18 Nov 2013, 22:03
P.S a picture would be good,see if we can rob any ideas :lol:
Ferrety
Post by Ferrety » 18 Nov 2013, 22:09
no camera so can't put up image,I've had a look on spec of camera nothing mentioned,would it be usual to have a mirror function?
Post by some bloke » 18 Nov 2013, 22:18
If you are using a car reversing monitor it has two camera feeds - one of them is reversed for reversing of all things. :angel:
Marky610
Post by Marky610 » 18 Nov 2013, 22:20
Hold a mirror infront of the screen and look at that, it will be the right way round then :thumbup:
I'll get me coat :mrgreen:
Dirt1427
Post by Dirt1427 » 18 Nov 2013, 23:18
I've got a mirror function but it's on the Osd on the monitor just a thought ?
weebster
Post by weebster » 19 Nov 2013, 00:53
You'll find it's the mirror function,just switch it over and all will be as it should be....I have a cheapy sony cam here with the same in the menu,can flick it to show a mirror image etc.
AirRifleSport
Post by AirRifleSport » 19 Nov 2013, 02:18
If it is the mirror mode, this can be found within the picture adjustment menu, in the camera, assuming that you have the facility to get on to the OSD menu.
Ferrety
Post by Ferrety » 19 Nov 2013, 07:31
thanks for the input,I'll have a play about with it and see what I can find,thanks :thumbup:
