16 or 18 mm lens??
The marsh
16 or 18 mm lens??
Post by The marsh » 17 Feb 2013, 21:24
Is it a 16 or 18mm I need to see more of scope view as using a 25mm and only see centre of scope
Gingernutz
Re: 16 or 18 mm lens??
Post by Gingernutz » 17 Feb 2013, 22:05
Most people prefer the 16mm lens. I seem to remember Some Bloke did a comparison drawing of a 16 and a 12 to show the field of view of them both.
terry1001
Post by terry1001 » 17 Feb 2013, 22:15
The marsh wrote:Is it a 16 or 18mm I need to see more of scope view as using a 25mm and only see centre of scope
the 16mm lens will give you a wider field of view, you will get a circular illuminated area with a black surround and effectively lower magnification. If the black area around the lit part is a significant size it will tend to affect the exposure and the central part will be brighter than it should be and may produce white out in some parts. If the whole of the sensor is lit, and there are no or very small black areas, the auto exposure will produce a more balanced image.
Some people prefer the circular view but this requires a higher scope magnification than with a full sensor image for the same size on the monitor. Seeing 'only the centre of the scope' just means you are getting a higher magnification at the monitor. At the end of the day it is a personal choice.
Post by some bloke » 18 Feb 2013, 08:20
I wish I could have said all that. Ruddy good balanced answer. :thumbup:
I'd add it also depends on your scope minimum magnification. A 25mm lens would just crop a tiny bit off the image edges at 3 mag scope, a tad more off to about the corners of a 4 mag scope and there is definitely no trace of the scope corners as you approach 5 mag. Lots of guys use 6 mag scopes so you will almost definitely need a 16 mm one for that. If you are using a watec camera it was designed to use a 1/2" format lens although some manage good results with a 1/3" format if lots of light will be used.
snoopy
Post by snoopy » 18 Feb 2013, 21:29
1/3 sencor with a 16mm MTV(board cam) lens on 2.5 scope mag is about what i see on 5-6 through just the scope... thats on mine though.
terry1001
Post by terry1001 » 18 Feb 2013, 22:07
snoopy wrote:1/3 sencor with a 16mm MTV(board cam) lens on 2.5 scope mag is about what i see on 5-6 through just the scope... thats on mine though.
That's about what I would expect, the 16mm lens on a 1/3" sensor gives about 2x mag, the benefit of having the extra magnification on the camera is that you make the most of the scopes light gathering at lower mag. With a larger scope objective you can probably afford to go up a little bit in magnification before performance starts to drop off. Generally you won't notice any dimming of the image because the camera will increase the gain to compensate but you will start to get increased 'noise' and a loss of image quality. My personal preference is to keep the scope at a minimum mag and use a longer focal length lens on the camera, but - as always - each to his own!
snoopy
Post by snoopy » 18 Feb 2013, 22:16
Terry? what mag equivelenta for the 1/2 and a lens, 1/3 or 1/2 lens? i'd like about the same as the mtv lens on that scope.
terry1001
Post by terry1001 » 18 Feb 2013, 23:00
snoopy wrote:Terry? what mag equivelenta for the 1/2 and a lens, 1/3 or 1/2 lens? i'd like about the same as the mtv lens on that scope.
As a rough guide if you take the sensor diagonal measurement which for a 1/2" lens is about 12mm then a lens of that focal length gives about 1x magnification so for 2x you'll want a 25mm lens and a 100mm lens about 4x.
1/3" sensors are about 8mm diagonal so a 16mm lens gives 2x, a 1/4" sensor is 6mm diagonal and a 12mm lens will give 2x.
Unfortunately you can't be sure that the sensors are the size claimed but this is near enough to give a fair idea.
snoopy
Post by snoopy » 19 Feb 2013, 01:36
its more of a clue than i had ty
The marsh
Post by The marsh » 21 Feb 2013, 23:47
Any idea on best 16mm for watec??
