Attach Ir torch to project box
7775rich
Post by 7775rich » 19 Feb 2018, 23:33
Hi
I want to add an ir torch/illuminator to the front of a project box and have it cut down and put battery inside box, just wondered best way to attach and if anybody offers a solution I can buy?
Cheers Rich
Re: Attach Ir torch to project box
Post by phoenix » 19 Feb 2018, 23:55
Screw a short section of picatinny rail to the box and then use a picatinny scope ring to suit your illuminator.
ANT Supplies has loads of cheap bits of picatinny rail https://www.ant-supplies.uk/rails-and-a ... rails.html and scope rings
7775rich
Post by 7775rich » 20 Feb 2018, 00:03
Hi
Yep that would work.
Ideally though want to mount to front of box and cut down short and also house battery inside
Etc ,
Regards
Rich
Post by phoenix » 20 Feb 2018, 08:03
OK, I've done this but it's a bit fiddly.
Drill a hole in your project box so that the tube of your illuminator just fits.
Fix a scope ring to the inside of the surface of the box so that when the illuminator tube goes through the hole it also passes through the hole in the scope ring.
Tighten the scope ring and the illuminator is held in place.
To fix the scope ring to the inside surface of the box I normally fit the illuminator through the hole in the case and through the scope ring and then tighten the scope ring. Use a clamp to hold everything in place and then drill 2 holes through the box and into the face of the lower half of the scope ring.
I then tap the new holes in the scope ring to M3.
Then, simply screw the scope ring onto the inside surface of the box.
Kevgun
Post by Kevgun » 20 Feb 2018, 10:36
Send me your torch with a mark where you want it cut, then i will screw cut the inside of the cut down torch body, then make up a boss which you bolt to your project box then just screw on the torch thread the wires through and Bobs you Uncle, it's easier than it sounds.
Trackerman
Post by Trackerman » 20 Feb 2018, 20:22
if your torch is a T20 then I have the solution...
This is a 3d printed mount for the rear cap.
https://www.thingiverse.com/thing:2800967
This way you still use full torch, battery remains in side the torch and you need a pigtail switch to activate it... cut the switch cable and fit a standard switch...
cheers
Tracker
Trackerman
Post by Trackerman » 20 Feb 2018, 20:31
And if it's a more modern torch like the T38, T50, T67 or T75 then this is the mount you need.
https://www.thingiverse.com/thing:2800979
just use the front of the torch, no cutting needed.
Then wire direct to the PILL regulator board.
or make a dummy battery to connect to the positive spring. but be sure to make a good ground to the torch case for negative.
T
Garyshaw
Post by Garyshaw » 20 Feb 2018, 20:53
Kevgun wrote:Send me your torch with a mark where you want it cut, then i will screw cut the inside of the cut down torch body, then make up a boss which you bolt to your project box then just screw on the torch thread the wires through and Bobs you Uncle, it's easier than it sounds.
How much do you charge for this service?
Kevgun
Post by Kevgun » 21 Feb 2018, 11:38
Pm me, I'm sure we can sort something out.
7775rich
Post by 7775rich » 25 Feb 2018, 00:10
Many thanks for reply’s have attached with the scope ring method- secure and works well
Although fried my t20
When soldering on wires -new pill on order lol
