Is it the boardcam, or the scope...
Daan
Post by Daan » 15 Dec 2015, 11:09
Hi guys,
I just introduced myself here on the board, where I also posted pictures of my diy NV build:
viewtopic.php?f=16&t=13570
Yesterday I've done some shooting with my setup and came across some issues...some of them I found a solution for, but for one I wanted to gather some advice from you guys. I've seen some of your videos and it seems like you are getting more viewing distance with some of your (likely the same) setups.
I found it hard to see details with the Ir fully focused on 10x mag at targets further than +- 60 meters!?
I tried all the different setting from the camera in the OSD and also removed the Ir filter before mounting all together.
I'm running a 700tvl boardcam, 12mm lens (16mm broke accidentally), 4.3" tft, 12V 1800mah Lion, T20 Ir torch icw a 3-12x40sf Discovery VT scope.
This is the camera I used:
And here are the given specs from the sellers add:
Features:
1/3 Inch SONY Effio-E DSP CCD
700 TVL High Resolution
Mini Illumination 0.01lux
16mm Lens
Audio output
OSD Menu
8 Language to choose
Mini 36*36mm Size
Specifications:
Image Sensor: 1/3'' SONY Effio DSP CCD
Pixel : PAL:976 (H)× 494(V) NTSC :976 (H) ×582 (V)
Horizontal Resolution : 700TVL
Sensitivity :0.01Lux
Lens :16mm
Angle:20 Degree
Audio output: Yes
Video Output :1.0VP-P / 75 ohm Video 0.714V p-p Sync 0.286Vp-p
Sync. System: Internal Sync
Luminance S/N Ration :50dB Min ( AGC off )
ESC: (NTSC - 1/60 ~ 1/60.000), (PAL – 1/50 ~ 1/60.000)
Manual Shutter: 1/60, 1/250, 1/700, 1/1K, 1/1.6K, 1/2.5K, 1/5K, 1/7K, 1/10K, 1/30K, 1/60K, 1/120K
DNR: LOW, MIDDLE, HIGH, OFF
White Balance: ATW / MANUAL / PUSH
SBLC: OFF / LOW / MID / HIGH
AGC :OFF, ON
Day / Night :COLOR, B/W, EXT, AUTO
Motion Detection :ON / OFF (4 Programmable Zone)
Privacy :ON / OFF (4 Programmable Zone)
Mirror :HORIZONTAL
Sharpness :1 - 20
OSD Language :Chinese/English/Spanish/Japan/French/ German/Portuguese/ Russian
Supply Voltage :12V DC (+10% -20%)
Power Consumption :180mA / 2.2W (Max)
Operating Temperature: -10 C to +50 C / (Humidity) 30% to 80% RH
Should be good I think, or am I missing something here?
Could it be the scope? I noticed that the scopes ability to give a nice bright image in dust or dawn isn't that good at the 'higher' magnifications...
Hope to hear from you guys soon!
Jirka
Re: Is it the boardcam, or the scope...
Post by Jirka » 15 Dec 2015, 11:22
Can you post some footage? The problem is most likely a low sensitivity of your camera, but it could also be other things. Two come to my mind right now:
- wrong focus match between the camera lens, scope's focus/parallax setting and ocular dioptric correction. Have you played around with these settings and their combinations? Does it work fine in daylight at the same distance?
- bad exposure set by your camera - have you tried different power levels of your illuminator? Does the ir light cone fully cover your field of view at that distance?
BTW: it is quite normal for zoom scopes to produce darker image at higher magnifications. In the daylight you usually do not notice and you only start to observe this when your eye's iris is fully open.
Daan
Post by Daan » 15 Dec 2015, 11:36
Hi,
I perfectly adjusted the eyerelief for the camera, tried with the parallax also.
The Ir torch can only focus, there's just one powermode on or off.
I'll try to shoot some footage this evening and also post my current settings from the OSD.
Daan
Post by Daan » 16 Dec 2015, 16:20
Yesterday the new 16mm lens came in. I did also reset the camera before I shot the video. Don't mind the fingerprints on the screen ;)
Houses are about 100yards away, when you hear the click I switched on the T20 uniquefire Ir torch and than focused it to achieve a better image.
https://youtu.be/7MQ7NMVJTi4
Daan
Post by Daan » 20 Dec 2015, 23:55
:silent: someone an opinion?
Jirka
Post by Jirka » 21 Dec 2015, 07:34
Well, it looks like the ir light cone only covers part of the area captured. That might lead to all kind of weird behavior if the camera is set to auto exposure. Were you using auto exposure or manual shutter setting.
But generally the level of detail is not too bad I would say - for a cheap Sony Camera.
Daan
Post by Daan » 21 Dec 2015, 09:47
It was on auto.
Tonight I'll try it on manual with shutter on 1/50 and AGC on 30.00
Jirka
Post by Jirka » 21 Dec 2015, 11:34
Also try to adjust the beam so that it covers the whole image evenly.
MrNewbie
Post by MrNewbie » 01 Jan 2016, 12:07
Daan wrote:It was on auto.
your missing the boat.. Try it on Manual with a FLD of 2 or 4.
Daan
Post by Daan » 01 Jan 2016, 12:11
What's fld?
